av reciever should I use?
I can't find anyone in Nashville like tweeters that showcase the lsi series all the online dealers like curcuitcity only have monitor speakers. I will keep looking.
KeithHt:
Yamaha rx v2700
Adcom GFA-7707
Lsi 15 frontL/R
lc265i center
lc265i side L/R
lc265i back L/R
PSW 1000
samsung 710AE projector -
Still waitng for K to respond. F1 nut hope I didn't offend you not my intention I do appreciate your input.
Doc Keith
You will only offend him if you keep asking for John Kerry's opinion, I mean John K.
oopss -
Ok. So I went with the yamaha for pre amping it sounds ok but doesn't wow thats for sure. The lc265i's seem to sound better than the lsi 15's.
I bit the bullet and bought new Adcom GFA-7707 7ch because of space.
Does anyone have that amp or listen to it with the lsi series?
Hopefully the amp will get here before the weekend I will let you know when I get all hooked up.
DocHt:
Yamaha rx v2700
Adcom GFA-7707
Lsi 15 frontL/R
lc265i center
lc265i side L/R
lc265i back L/R
PSW 1000
I would recommend a Denon AV Surround Receiver. I have had the Denon AVR-587 for a little over a year now. The performance is exceptional. Not to mention, it has every possible input and output you could imagine. For the price, it's definitely worth every cent I spent. Check out this link:
http://www.usa.denon.com/ProductDetails/AVReceivers.asp
Prices very from $350 to $7000. All of them have the HDMI you are looking for. -
Here are the specs for the AVR-588
7.1 CH/5.1+2 CH Home Theater Receiver
This Model retails for about $350- 75 watts x 7 channels
- Analog Devices Melody 100 32 bit floating point DSP processing
- 7.1 channel analog EXT input for HD audio sources
- Component video switching
- HDMI v1.3a video switching with deep color support (no audio)
- 24bit/192kHz A/D
- XM Radio ready
- XM-HD Neural sound
- Network ready
- Dedicated iPod port for use with optional ASD-1R D-dock
- Network ready with optional ASD-3W/3N iPod dock
- Variable low/high-pass crossover
http://www.usa.denon.com/ProductDetails/3643.asp
