Onkyo TX-SR605 / RM7500 crossover settings
hrn023
hrn023 Posts: 1
I have had my RM7500 for a while now and finally upgraded to a worthy receiver.
What settings are recommended for the crossover of the fronts/center/rear and sub (Low Pass Filter for the LFE)
right now the fronts/center/rear are set for 80
the sub is set for 120.
thanks!
  • xandra
    xandra Posts: 291
    edited June 2008
    One very knowlegeable contributer here (don't recall name) reccomends setting to 15 or 20 above the -3db level of the speakers.
    so for example if the -3db level is 50 you could set the to 65 or 70... (don't think 65 is an option, so you'd set it 70)
    I used this as a guideline and think it's a great starting point
    LR Setup:
    Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
    Onkyo 705 & Denon 3808ci Receiver, Onk 875
    Parasound 2250 Amp
    Sony 26" KDL series Bravia LCD
    Panny DMR-EH75 Recorder
    Panny DVD-F87 (5 disk DVD player)
    NAD T585 (DVD/SACD)
    Yamaha DVD-C961 (5 disk SACD/DVD)
    SciAnt Explorer 8500HD Cable Box
    Orig & 5Gen iPods, , Wii
    Plans/Fantasies:
    • 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
