Onkyo TX-SR605 / RM7500 crossover settings
hrn023
I have had my RM7500 for a while now and finally upgraded to a worthy receiver.
What settings are recommended for the crossover of the fronts/center/rear and sub (Low Pass Filter for the LFE)
right now the fronts/center/rear are set for 80
the sub is set for 120.
thanks!
thanks!
One very knowlegeable contributer here (don't recall name) reccomends setting to 15 or 20 above the -3db level of the speakers.
so for example if the -3db level is 50 you could set the to 65 or 70... (don't think 65 is an option, so you'd set it 70)
I used this as a guideline and think it's a great starting pointLR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
