Home Made Tube Dampers
zingo
I heard of the idea of getting a tube of high-temp caulk/sealant from the hardware store, and running a bead or two of it around your tubes. They claim it dampens and withstands the heat. The "dampers" wouldn't be removeable, but if you don't care, does it matter? I'd love to hear your thoughts friends...
Post edited by zingo on
Bad idea. Just buy tube dampers. They're too cheap to consider for DIY. Check ebay.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Try it & let us know if anything bad happens!!
I will be buying mine.Michael
NORTH of 60° -
Alright alright; I'll just buck up and buy some. But for discussion sake, what makes it such a bad idea?
