Home Made Tube Dampers
zingo
zingo Posts: 11,258
edited June 2008 in Electronics
I heard of the idea of getting a tube of high-temp caulk/sealant from the hardware store, and running a bead or two of it around your tubes. They claim it dampens and withstands the heat. The "dampers" wouldn't be removeable, but if you don't care, does it matter? I'd love to hear your thoughts friends...
Post edited by zingo on
  • Early B.
    Early B. Posts: 7,900
    edited June 2008
    Bad idea. Just buy tube dampers. They're too cheap to consider for DIY. Check ebay.
    "God grooves with tubes."
  • george daniel
    george daniel Posts: 12,096
    edited June 2008
    ^^^^^what he said^^^^^
  • pearsall001
    pearsall001 Posts: 5,384
    edited June 2008
    Try it & let us know if anything bad happens!! ;)
  • janmike
    janmike Posts: 6,146
    edited June 2008
    I will be buying mine.
    Michael ;)
    NORTH of 60°
  • zingo
    zingo Posts: 11,258
    edited June 2008
    Alright alright; I'll just buck up and buy some. But for discussion sake, what makes it such a bad idea?
