brrrrrrr
EcinEcin Posts: 61
edited June 2008 in Car Subwoofer Talk
i don't know what's up with my system in some songs i get a brrrrrr sound in other songs they sound fine. I'm not talking about the car vibration or anything like that. I'm talking about the actual sound that the subwoofer is actually putting out. I have 2 500/1 jl audio and 2 sr124dvc they both are connecting it separately.
So basically on some songs it hits just fine ( not too loud :( ) but on other songs the bass is a long vibrating sound. When I hear the same song in a club or what not it doesn't sound that way. do i have to make it High pass and cut off a certain low frequency?
Post edited by Ecin on
  • EcinEcin Posts: 61
    edited June 2008
    PS. they are both in sealed enclosures the exact same size that polk specified on their site.
  • Airplay355Airplay355 Posts: 4,294
    edited June 2008
    Are you using mp3s?
  • BradimusMaximusBradimusMaximus Posts: 60
    edited June 2008
    If both subs are doing it and both subs are separately powered and hopefully in separate enclosures then I would think its an input related problem. Gain to high, very poor mp3 is plausible, bad RCA connections or cables.
    Pioneer Premier DEH-P980BT
    Alpine SPX-137R
    Alpine SPR-69LP
    Panasonic CY-PA4003U
    Kenwood KAC-X520
    Polk SR124 :D
    edited June 2008
    Airplay355 wrote: »
    Are you using mp3s?
    yes i use mp3s, but i thnik i had this problem on a CD as well, don't remember. How should I rip mp3s? I'll check my RCA's as well I'm not sure I have good RCA's to the sub.
  • JstasJstas Posts: 13,773
    edited June 2008
    There is no useful information in this thread to diagnose your problems at all.
    Who did your install?
  • JethroJethro Posts: 28
    edited June 2008
    If this sound only happens at high volume, it is most likely clipping. Find a song that does it, and then turn it down a few notches while it's doing it to see if it stops.
    Have you done any electrical system upgrades to your car?
    Friends don't let friends listen to Bose.
  • MacLeodMacLeod Posts: 14,365
    edited June 2008
    ^^^ x2
    Check your gains. If theyre set over halfway, theyre set too high and youre likely clipping your amp(s).
  • stipoystipoy Posts: 2
    edited June 2008
    hi ecin, any luck with solving your problem? im actually experiencing the same thing. it seems that the really low notes are over-emphasized. i checked the size of my enclosure and it was 1.2 cu ft, where the recommended was .88, im not sure if it's the cause. let me know when you find a solution, let's compare notes :)
    edited June 2008
    stipoy wrote: »
    Yep really low notes, especially. It doesn't happen @ home and i have a deep sounding onkyo subwoofer powered by onkyo receiver about 100w. Or my sister's car, or the stock harmon kardon i had before.
    http://www.polkaudio.com/caraudio/subbox/subbox_plan.php?id=96&mesurements=standard I have 2 mdf 3/4" with those specs
Howdy, Stranger!
