Source changing switch for an amp
MillerLiteScott
I have been in the process of looking to do a DIY amp but I don't know much so I am starting off simple using the guts of a RS deal of the century amp.
Basically I would like to add a source switch and replace the front board controls with just a volume control/pot. And would it also be possible to create just a straight through to the amp source.
I have not been able to find any source switches or I am not looking for the right thing. And are there any other resisters or op amps needed to do this?
Scott
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
You can get decent source switches from Digi-Key for less than ten dollars.They can switch up to 6sources.And no op amps/buffers are needed. I will look up a part # for you later this evening if you like.Testing
Testing
Testing -
Sounds great.
Thanks GV#27
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
If you don't already have one order a free 2200 page catalog from digi key.It is full of goodies for the DIY/modder.http://www.digikey.com/
The digi key part # for 2 possible switches are the Electroswitch 451-1028-ND $10.28
and the E-Switch EG1954-ND $6.16
Both are double pole with up to 6 positions.Testing
Testing
Testing -
Thanks. I will look into those.
Scott here is a pdf of digi keys cat. with the Electroswitch part.Scroll down to the section labeled C5. Its only $9.50 in US funds.
http://dkc3.digikey.com/PDF/T082/2030-2033.pdfTesting
Testing
Testing -
Thanks again GV#27. That looks like it will do the trick.
