Source changing switch for an amp
MillerLiteScott
MillerLiteScott Posts: 2,564
edited June 2008 in DIY, Mods & Tweaks
I have been in the process of looking to do a DIY amp but I don't know much so I am starting off simple using the guts of a RS deal of the century amp.
Basically I would like to add a source switch and replace the front board controls with just a volume control/pot. And would it also be possible to create just a straight through to the amp source.
I have not been able to find any source switches or I am not looking for the right thing. And are there any other resisters or op amps needed to do this?
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
  • Systems
    Systems Posts: 14,872
    edited June 2008
    You can get decent source switches from Digi-Key for less than ten dollars.They can switch up to 6sources.And no op amps/buffers are needed. I will look up a part # for you later this evening if you like.
    Testing
    Testing
    Testing
  • MillerLiteScott
    edited June 2008
    Sounds great.
    Thanks GV#27
    Scott
  • Systems
    edited June 2008
    If you don't already have one order a free 2200 page catalog from digi key.It is full of goodies for the DIY/modder.http://www.digikey.com/
    The digi key part # for 2 possible switches are the Electroswitch 451-1028-ND $10.28
    and the E-Switch EG1954-ND $6.16
    Both are double pole with up to 6 positions.
    Testing
    Testing
    Testing
  • MillerLiteScott
    edited June 2008
    Thanks. I will look into those.
    Scott
  • Systems
    edited June 2008
    Scott here is a pdf of digi keys cat. with the Electroswitch part.Scroll down to the section labeled C5. Its only $9.50 in US funds.
    http://dkc3.digikey.com/PDF/T082/2030-2033.pdf
    Testing
    Testing
    Testing
  • MillerLiteScott
    edited June 2008
    Thanks again GV#27. That looks like it will do the trick.
    Scott
