Monster XP-CI wire Vs others?
paymontna
paymontna Posts: 188
Monster XP-CI speaker wires vs. the 12 awg braided speaker wire from Lowes? What are the technical advantages?
And I mean calling all cars, blackhawk down, mushroom cloud, Three Mile Island, lock the door behind you kind of mad.:mad:
Post edited by paymontna on
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited June 2008
    There are no technical advantages.
    F1nut Posts: 51,719
    edited June 2008
    Technical advantages? I think you should be more concerned about the sound differences.
  • paymontna
    edited June 2008
    I know what the sound differences are. I was wondering what specifically improves the audio quality.
  • WilliamM2
    edited June 2008
    paymontna wrote: »
    No one seems to know. It must be magic.
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2008
    It's not a matter of "improving" the sound, it's the tonal character the cable imparts on the signal because of it's materials, topology, design, insulator, etc. I have personally never noticed any difference between 12ga multi-strands, regardless of maker. I have noticed differences in the tonal quality of multi-strand and solid copper conductor type cables. Some people detect these differences, others don't. I think the point F1 was making is that you prbably need to "hear" them rather than speculate on what you've read about them--or depend on someone elses opinion. IOW, make up your own mind if the differences are there. Either way you're getting the full audio bandwidth.
    As far as this Monster "magnetic flux tube" thingy, who knows. Probably an expensive theory. You would probably be fine to just buy some good quality multi-strand and not worry too much beyond that, unless you're looking for a higher end cable.
  • Gaara
    Gaara Posts: 2,415
    edited June 2008
    There are some members who believe in science. They generally believe that if there are differences between wires then there should be measurable differences, since measuring equipment is much more sensitive then human ears ever will be.
    The flip side is the members who believe there is more to it then just measurements. They believe that many audio attributes can't be properly measured, and therefore even if two items such as speaker wire measure the same there can be differences between them.
    That said the differences between the two wire will be gauge, % oxygen free, geometry, etc. and the measurable difference will in capacitance, inductance, resistance etc.
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    Gaara wrote: »
    Thus the magic...:p
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • steveinaz
    edited June 2008
    But oddly, even those who claim science over experience aren't running 18awg lamp cord and the 49 cent ic's that came with their equipment--even though science dictates they are capable of carrying the full audio spectrum. Hypocrisy? You make that call. I call it subjective preference.
    The only opinion you need in this hobby is located on each side of your head, they never lie, and will let you know immediately if you've made a bad choice. So rock on.
  • WilliamM2
    edited June 2008
    steveinaz wrote: »
    But oddly, even those who claim science over experience aren't running 18awg lamp cord and the 49 cent ic's that came with their equipment--even though science says they are capable of carrying the full audio spectrum. Hypocrisy? You make that call. I call it subjective preference.
    Call it what you want, but science tells us that 18ga cable will add too much resistance for the 30 foot runs I have to my mains. Science also tells us that the 49 cent IC's are not shielded well enough to reject noise. It's easily measurable. How is that hypocrisy?
    Most of us also have experience, what we seem to lack is a vivid imagination.
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    NNONOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Not again...
    ....ok I'm listening.:p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • steveinaz
    edited June 2008
    WilliamM2 wrote: »
    Absolutely, that length would require a higher gauge (well, arguably. it could be done, but it's not ideal or recommended)--but I agree. I'm not arguing with the science--I whole-heartedly agree, but I believe there's more to it than just the science. Science, specified measurements required for a cable to perform the way it was intended is of course important--in fact paramount, but I believe it's only a piece of the puzzle.
    IME, 49 cent IC's work just fine if routed properly--so I disagree with you on that point.
    When I say "experience" I mean the experience of listening to the cable--not in terms of years of knowledge. Vivid imagination?--maybe, but what difference does it make, it's my dime, my decision, my system. Right?
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    The Martians did it...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Face
    Face Posts: 14,340
    edited June 2008
    WilliamM2 wrote: »
    Are you sure about that?
    http://www.roger-russell.com/wire/wire.htm#wiretable
  • WilliamM2
    edited June 2008
    steveinaz wrote: »
    I knew what you meant by experience.
  • WilliamM2
    edited June 2008
    Face wrote: »
    Positive, I use 4 ohm speakers.
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    My cable bill is way too high...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    Lets all go wireless....
    ....nevermind ...then we would fight about the different transmitters.. and how the signal changes with different temperatures,. and what setting on our thermostats would be optimal for signal transfer......and the fight over humidity levels...and distance and at what angle the signal should travel...
    ..scratch that idea...
    ...I like Mars....
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    F1nut Posts: 51,719
    edited June 2008
    It's a well estabished fact that you, William, can't hear a difference, so why you bother to discuss anything to do with cables is beyond me. You seem to have that, I'm miserable and I want everyone else to be also, mentality. The funny thing is, no one ever seems to want to join you.
  • Face
    Face Posts: 14,340
    edited June 2008
  • WilliamM2
    edited June 2008
    It's also a well established fact that NO ONE has been able to prove they hear a difference in a double blind test. Wierd, since so many claim that they could do it.
    I'm not miserable at all, instead of constantly listening to my cables, I listen to music. Odd concept.
    If you have no wish to discuss it, then don't reply. Simple really.
  • WilliamM2
    edited June 2008
    Nice attemp at trolling, Face.:rolleyes:
  • Face
    Face Posts: 14,340
    edited June 2008
    I feel bad for you since you can't hear a difference.
    F1nut Posts: 51,719
    edited June 2008
    What's to discuss with you? Obviously, you're deaf.
  • dave shepard
    dave shepard Posts: 1,334
    edited June 2008
    Keiko wrote: »
    Martian Cable
    Catchy! I like it. :D
    Sounds too much like Monster Cable they will have to sue ya.
  • steveinaz
    edited June 2008
    Hey, live & let live.
    You don't hear a difference, fine. State your opinion and move on--but it's always an "offensive" against those of us who do hear differences. Let's call it an insecurity. It's one thing to have an opinion, it's quite another to discount everyone elses because you think the earth is flat. Nobody cares. People will (hopefully) make up their own minds armed with the knowledge that the coin has another side.
    Why would I need to prove anything to anyone? I couldn't give less of a **** how you feel about me, my methods, or my decisions. I'm just throwing some observations out there that may (or may not) be worth investigating. Get over yourself.
  • WilliamM2
    edited June 2008
    steveinaz wrote: »
    You realize everything you said goes both ways. You hear a difference, fine state your opinion and move on.
    But no, the "believers" must result to insults and name calling. Insecure, hypocrite, deaf, whatever. Why? Because you have absolutely nothing to back your claims.
    It's pretty clear who's insecure.
  • Gaara
    Gaara Posts: 2,415
    edited June 2008
    steveinaz wrote: »
    I never understood this mentality, the false dichotomy of either you believe in science and use the cables that came in the box, or you don't and use fancy stuff always bugged me.
    I can't really hear differences between cables, I have stated this before. With that said I do not use cheap cables that come in the box, I use specs to make my decision. Perfect example, digital coax, this should be familiar to you Steve. I chose Belden 1694a the reason for this decision was it was of a sufficient gauge, was very well shielded, had a low capacitance and was the right impedance. This $15 cable meets all the requirements of a good performing digital coax, so I am content with this decision.
    It isn't that I don't believe there are difference between cables, I do, but I feel that they are easily measurable. I am sure if you compared the specs of 1694a to that DH Labs you used previously you would find measurable differences which reflect what you are hearing. I am not saying you should use science over your own ears, but you could have found your grail long ago if you paid attention to specs.
  • Gaara
    Gaara Posts: 2,415
    edited June 2008
    jakelm wrote: »
    Its all about the majic. And there is a cable designer out there that recommends plants for humidity control, more for driver performance then cables though...I think it was someone from Cardas.
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2008
    I bet I can hang myself with any cable or interconnect, and it would work just fine....but if I'm going out that way, it's esoteric baby.
  • Face
    Face Posts: 14,340
    edited June 2008
    Gaara wrote: »
    I'll let you know next time I invite some Polkies over, so we can show you the light. :D
