what size wire with rm10 set...
hdoggie24
got a rm10 speaker set. either getting a onkyo 605 or 606 or maybe something else comparable. what size speaker gauge wire is recommended for this setup for optimum performance. any info will help. thanks.
Post edited by hdoggie24 on
First welcome to Club Polk!
Second how long are your runs?
Third what type of budget are you working with.
Ben -
probably 15-20ft for the surround. front wall mounted next to tv. thanks i love polk products. don't know about budget. just trying to get good quality from this system for right now. later on i might upgrade to better fronts. but not looking for the best system.
Signal cable is great wire that is terminated, and custom lengths are available. Frank has a great reputation, and makes a great product. If you want real cheap you can get 14ga wire in the auto section at WalMart. The stuff in electronics is over priced, and not as good. Monster is way to pricey for its performance.
Ben
http://signalcable.com/index.htmlPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I started with the RM10 package myself and have about the same room size as yours. I used 14g speaker wire (from Radio Shack). The wire rolls didn't cost much and I'm happy with the sound I have now.got a rm10 speaker set. either getting a onkyo 605 or 606 or maybe something else comparable. what size speaker gauge wire is recommended for this setup for optimum performance. any info will help. thanks.
BTW, I later upgraded my fronts to RM 201's. I'm really happy I did that. That's what the center speaker of the RM10 package is. If you upgrade your fronts by replacing the RM101's you've set yourself up for a 7.1 system.
Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN... -
I'd just use 12g speaker wire from RadioShack, Home Depot, etc.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Welcome to the forumI refuse to argue with idiots, because people can't tell the DIFFERENCE!
Welcome to Club Polk!!!!!
I used 14ga stranded speaker wire from the local hardware store. It was about .50cents/foot and it made a big difference over the 18ga.
The rears required 50' of cable to get to the back of the 12'deep room.
http://www.polkaudio.com/forums/showcase/view.php?userid=88673 -
Welcome to the forum. 14g seems to work well, but can be a little inflexible depending on installation. If that's true, just jump down to 16g.
I used 16 gauge from Monoprice for a similar distance and the sound is excellent.
