Recommendations for cordless phones
Norm Apter
Right now I've got a single GE 5.8 GHz and a single no-name brand (Ativa) 2.4GHz, the latter of which I got at Office Depot for $10 (after mail-in rebate). Now -- a year later -- I know why it was only $10 (pretty poor quality).
I'm wondering if anyone here has had good luck with any brands/models of cordless phones. It seems like cordless phones are getting higher and higher in Hz (I remember an old one that was 900 Hz), but I'm not sure whether these advances translate into real improvements. I know that there are a lot of well-known brands out there, but I'd like to hear recommendations based on personal experience, with clarity being the crucial consideration.
I'm leaning toward replacing both, hopefully with a two-unit set (if one has answering machine, all the better).
Thanks.
Thanks.
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
HT
Denon 2808ci AVR
Post edited by Norm Apter on
Get DECT 6.0 based phone and you wouldn't have to worry about interference etc. I am using following Panasonic set for 6 months and am very happy so far:
http://www.amazon.com/gp/product/B000LYA8UW-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
I used a set of Uniden like this setup with answering machine for a couple years and loved it. Cost was $179 when I bought it....$64 bucks would be a great deal. 5.8Ghz was crystal clear and no interference with other devices for me.
http://www.amazon.com/gp/product/B000E60HJO/ref=pd_cp_e_3?pf_rd_p=250314601&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B000LYA8UW&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=185Q9DGE5ND2RFYA7WBVHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I went with one of the new Panasonic 5.8GHz models......works great, as do the extra 3 handsets that came with the system.The first rule of Fight Club is you don't talk about Fight Club
I would recommend the Panasonic as well. I've had Sony, GE and Uniden and these Panasonics are the best yet!shadowofnight wrote: »I went with one of the new Panasonic 5.8GHz models......works great, as do the extra 3 handsets that came with the system."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
I second the DECT 6.0 panasonic set above. It replaced a combination of GE and a Panasonic phone last December. The Panasonic was about 10 years old, the GEs lasted maybe 5 years. I either got my new phones from amazon or buy.com. We got 3 handsets for about $80, so per phone they are even pretty cheap. They work great.
Another vote for Panasonic.
Also, I think that old set you had was 900MHz, not 900Hz.
If you will it, dude, it is no dream. -
lolz liek who really uses regular phone now?
it's all aboyut cell phone..
only etwigs and LAME must use regular phone..
it's all about VOPI maybe you have VOIP? then good
People who can spell and form correct sentences often use land line phones.
Idiots such as ihatethis must not be able to master the concept."Just because youre offended doesnt mean youre right." - Ricky Gervais
Panasonic phone?
I got one a 2 line cordless phone with answer machine, HATE that phone sounds like ****. Also own a VTech cordless phone system, which sounds great believe it is 2.4ghz but it's only marked as "Gigaphone" The only problem I have is the VTech phones are getting old and need a replacement, but been so turned off by Panasonic its way off my list.
In fact that phone may have a horrible death, only if I owned a tree limb cropper..... Bits and Pieces baby I what to have trouble saying what it was after.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I'm in my second set of Vtech and I am very happy with them; had a 900 MHz, and now I have a pair of 2.4 MHz that came as a set. You plug one to the phone line, and the other one you just plug to an electrical outlet for charging. They work great, both handsets have speaker phones, no interference at all with my wireless network, and what's most important to me is that the batteries last forever. I do a lot of conference calls when working from home and I can be 2 hours with the speaker phone.
Best of all, they are not expensive.
Befor Vtech I had a couple of Panasonic but had to replace batteries too often._________________________________________________
SOPAThank God for different opinions. Imagine the world if we all wanted the same woman
