Recommendations for cordless phones
Norm Apter
Norm Apter Posts: 1,036
edited June 2008 in The Clubhouse
Right now I've got a single GE 5.8 GHz and a single no-name brand (Ativa) 2.4GHz, the latter of which I got at Office Depot for $10 (after mail-in rebate). Now -- a year later -- I know why it was only $10 (pretty poor quality).
I'm wondering if anyone here has had good luck with any brands/models of cordless phones. It seems like cordless phones are getting higher and higher in Hz (I remember an old one that was 900 Hz), but I'm not sure whether these advances translate into real improvements. I know that there are a lot of well-known brands out there, but I'd like to hear recommendations based on personal experience, with clarity being the crucial consideration.
I'm leaning toward replacing both, hopefully with a two-unit set (if one has answering machine, all the better).
Thanks.
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
Post edited by Norm Apter on
  • izafar
    izafar Posts: 819
    edited June 2008
    Get DECT 6.0 based phone and you wouldn't have to worry about interference etc. I am using following Panasonic set for 6 months and am very happy so far:
    http://www.amazon.com/gp/product/B000LYA8UW
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited June 2008
    I used a set of Uniden like this setup with answering machine for a couple years and loved it. Cost was $179 when I bought it....$64 bucks would be a great deal. 5.8Ghz was crystal clear and no interference with other devices for me.
    http://www.amazon.com/gp/product/B000E60HJO/ref=pd_cp_e_3?pf_rd_p=250314601&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B000LYA8UW&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=185Q9DGE5ND2RFYA7WBV
  • shadowofnight
    shadowofnight Posts: 2,735
    edited June 2008
    I went with one of the new Panasonic 5.8GHz models......works great, as do the extra 3 handsets that came with the system.
    The first rule of Fight Club is you don't talk about Fight Club
  • shack
    shack Posts: 11,154
    edited June 2008
    I would recommend the Panasonic as well. I've had Sony, GE and Uniden and these Panasonics are the best yet!
  • polktiger
    polktiger Posts: 556
    edited June 2008
    I second the DECT 6.0 panasonic set above. It replaced a combination of GE and a Panasonic phone last December. The Panasonic was about 10 years old, the GEs lasted maybe 5 years. I either got my new phones from amazon or buy.com. We got 3 handsets for about $80, so per phone they are even pretty cheap. They work great.
  • bobman1235
    bobman1235 Posts: 10,822
    edited June 2008
    Another vote for Panasonic.
    Also, I think that old set you had was 900MHz, not 900Hz. :)
  • ihatethis
    ihatethis Posts: 14
    edited June 2008
    lolz liek who really uses regular phone now?
    it's all aboyut cell phone..
    only etwigs and LAME must use regular phone..
    it's all about VOPI maybe you have VOIP? then good :D
  • shack
    shack Posts: 11,154
    edited June 2008
    ihatethis wrote: »
    People who can spell and form correct sentences often use land line phones.
    Idiots such as ihatethis must not be able to master the concept.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2008
    Panasonic phone?
    I got one a 2 line cordless phone with answer machine, HATE that phone sounds like ****. Also own a VTech cordless phone system, which sounds great believe it is 2.4ghz but it's only marked as "Gigaphone" The only problem I have is the VTech phones are getting old and need a replacement, but been so turned off by Panasonic its way off my list.
    In fact that phone may have a horrible death, only if I owned a tree limb cropper..... Bits and Pieces baby I what to have trouble saying what it was after. ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Ricardo
    Ricardo Posts: 10,634
    edited June 2008
    I'm in my second set of Vtech and I am very happy with them; had a 900 MHz, and now I have a pair of 2.4 MHz that came as a set. You plug one to the phone line, and the other one you just plug to an electrical outlet for charging. They work great, both handsets have speaker phones, no interference at all with my wireless network, and what's most important to me is that the batteries last forever. I do a lot of conference calls when working from home and I can be 2 hours with the speaker phone.
    Best of all, they are not expensive.
    Befor Vtech I had a couple of Panasonic but had to replace batteries too often.
    SOPA
