Power Protection
jeepdog
hi just came into me i should get some power protection.I've been looking at a monster HTS-2600. should i get it and do they help sound and video at all. or what else is out there
Post edited by jeepdog on
Try here .
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=8531&highlight=power+conditionersPolk Rt800i -Fronts
Polk cs400i -Center
Polk fx500i -side surrounds
Polk rc60i -rear surrounds
Onkyo TX-NR 1009 (9.2) receiver
Velodyne cht12
Polk psw111 -
President of Club Polk -
yes you should get some type of power protection. There are many companys that offer great products. It would depend on how much do you want to spend & what level of protection do you want. make sure whatever you buy matches with your equipment. One feature you may want to have is filtering to remove noise from the ac line. hope this helps. as above check out the other posts.
