Power Protection
jeepdog
jeepdog Posts: 6
edited April 2003 in Electronics
hi just came into me i should get some power protection.I've been looking at a monster HTS-2600. should i get it and do they help sound and video at all. or what else is out there
  • begbie
    begbie Posts: 630
    edited April 2003
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Polk fx500i -side surrounds
    Polk rc60i -rear surrounds
    Onkyo TX-NR 1009 (9.2) receiver
    Velodyne cht12
    Polk psw111
    F1nut Posts: 52,371
    edited April 2003
  • ezc
    ezc Posts: 426
    edited April 2003
    yes you should get some type of power protection. There are many companys that offer great products. It would depend on how much do you want to spend & what level of protection do you want. make sure whatever you buy matches with your equipment. One feature you may want to have is filtering to remove noise from the ac line. hope this helps. as above check out the other posts.
