Sony PS3
leroyjr1
leroyjr1 Posts: 8,785
edited June 2008 in Electronics
Is their any way I can get my ps3 to play movies in blu-ray full screen. When I play it in BD it only shows widescreen. When playing SD-DVD I can use the projectors auto image to fill the whole screen if its a widescreen movie.
Any suggestions please help
Post edited by leroyjr1 on
  • leroyjr1
    edited June 2008
    anyone
  • jon s
    jon s Posts: 905
    edited June 2008
    i don't understand... you are using a widescreen projector, the PS3 should display full screen unless the aspect ratio is higher than 1.78:1 (e.g. 2.35:1). All Blu-ray movies are already widescreen.
  • leroyjr1
    edited June 2008
    I have a 16 x 9 110 inch screen and when watching Blu ray movies it does not fill the whole screen
  • jon s
    jon s Posts: 905
    edited June 2008
    you got black bars where... on the sides or top and bottom??? all around???? what type of connection??? component??? HDMI?
  • leroyjr1
    edited June 2008
    Black Bars on the bottom and top. I am using sony component cables. The previews and menu show full screen but as soon as the movie come on back to widescreen
  • Imperitor
    Imperitor Posts: 235
    edited June 2008
    Like Jon said, most movies are filmed in a wider aspect ratio then wide screen TV's. So you will still get small back bars on the top and bottom. The reason is that they are made for theaters, and most theaters have a very wide aspect ratio. The previews as specifically made for TV, so they were altered to fit the screen. Your TV might have a zoom feature that will fix this, but it will cut off the sides a little bit.
    7.1 HOME THEATER:
    Center: CSi3
    Front: RTi10
    Surround: RTi A3
    Rear Surround: RTi4
    Subwoofer: Mirage Omni S10
    TV: Sharp Aquos 42" 1080p LCD
    Receiver: Onkyo TX-SR805
    Blu-Ray Player / CD Player / DVD Player / Media Server / Game Console / Best money I've ever spent: 60GB PS3
  • jon s
    jon s Posts: 905
    edited June 2008
    Most new theatrical releases are now made with an aspect ratio of 2.35 or higher... which means even with your widescreen set, there will be black bars on the top and bottom. If you were watching on a 4:3 set, the black areas would be even larger.
    Your aspect ratio of the screen is only 16:9 or 1.78:1... most directors are now going to 2:35:1 which means an even wider screen is needed. Some of the newer projectors can now display 2.35:1 for people who buy 2.35 screens.
  • Monster Jam
    Monster Jam Posts: 919
    edited June 2008
    I'll say it in plain english: The black bars you see are normal.
    Do you hear that buzzing noise? :confused:
  • leroyjr1
    edited June 2008
    Them black bars look terrible
  • jon s
    jon s Posts: 905
    edited June 2008
    it looks a lot worse on a 4:3 tv set...
