RM6200-stardard hook up vs the Polk way
VDubFan
VDubFan Posts: 15
When I first purchased the RM6200 w/ my HK avr 110 I bought it as an open box item so I didn't get a manual with the system. So, I hooked everything up the traditional way and it sounded pretty good to me. Then, when I bought my HK avr 146 I hooked everyhting up the same way and it didn't sound as good. Then I found this site, downloaded the manual and saw the Polk Way of hooking everthing up, so I tried it and it sounded better. Then I read a thread on here a while back that said movies encoded with DTS send a LFE signal directly to the LFE channel, so if you have your speakers set up the Polk Way, you'll be missing out on some LFE signals. So, before watching Rambo on BD I hooked everthing back up the standard way and it didn't sound that great. I had to make a lot of adjustments. I've watched BD movies with DTS with my system hooked up the Polk Way and I thought they sounded pretty good. So, am I really missing out on anything with my speakers connected the Pok Way when watching movies encoded with DTS?
Sony 46" Bravia XBR4
Harmon Kardon AVR146
Sony PS3
RM6200 sat/sub system
PSW250
Post edited by VDubFan on
  • Jed Leland
    Jed Leland Posts: 182
    edited June 2008
    Hello,
    The Polk method is done to make sure the sub plays up, in frequency, to the low frequency ability of the sats. Usually this is around 120 to 150Hz. When you use the bass management, of the receiver, to have the fronts as "large" and the sub-out turned off the receiver will send the "LFE" information for either Dolby or DTS to the front speakers and since that's where the sub is connected you'll hear it fine.
    Cheers, Jed
  • VXR8
    VXR8 Posts: 291
    edited June 2008
    + 1 with what Jed said.
    I previously had my RTi10s, with my PSW505 and now my LSi9s still hooked up the Polk way - it sounds THAT much better to me that way. With my new receiver, I tried the sub out, but the bass from the sub just wasn't there.
    Enjoy the "Polk" way ;)
    Regards - Gaz from the land of Oz
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    Cambridge Audio - Azur 851C - CXUHD
    Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
    SVS - PB1000 x 2
    Foxtel - iQ4
    Belkin - Pure AV PF40
    Sony K77A9G
    Front Room System
    PS Audio - Sprout 100
    Cambridge Audio - CXC S2 - CA752BD
    Sony - UBX800 4K BluRay
    Polk Audio - Legend L200
  • VDubFan
    VDubFan Posts: 15
    edited June 2008
    Thanks for the replies. I decieded to connect everything back to the Polk Way. I just think it sounds better.
    Sony PS3
    PSW250
  • gfong
    gfong Posts: 1,079
    edited June 2008
    I agree as well. I have tried both ways with my satelites and the "Polk way" or passive sub woofer way sounds best to me.
  • singitloud
    singitloud Posts: 20
    edited June 2008
    I also went back and forth on this a few years ago with my RM6600 series - I ended up using the POLK way and LOVE it (though ALL the audio guys at stores say I'm stupid).
    Dwaine
    Sing... Worship... Live the Life
