Refurbing Carver faceplate?
dylanblada
dylanblada Posts: 77
edited May 2008 in Electronics
So I think I'll be keeping my Carver (unless I get any good offers...) But it has a few cosmetic isses I'd like to fix up if possible. As you can see in the pics, I have two issues (poorly) drilled rackmount holes and medium depth scratches. Is there much that could be done? I would Bondo the holes and paint it black if it wasn't for the logos and such. Would sanding take care of the scratches? What grit? Any other ideas? Someone wanna trade for a clean faceplate (+cash of course)?
  • dorokusai
    dorokusai Posts: 25,638
    edited May 2008
    Shoot an email to Lasareath. He located a metal fabricator that might be able to help you out.
  • Rivrrat
    Rivrrat Posts: 2,101
    edited May 2008
    I wouldn't sand it myself. I'm sure that's an anodized finish, and you'll end up sanding it down to bare metal
    My equipment sig felt inadequate and deleted itself.
