Candela Tube swap
VR3
VR3 Posts: 29,697
edited June 2008 in Electronics
I swapped my tubes with some JJ Tesla tubes like Bunky suggested on Audiocircles..
What a difference in staging --
Far more precise, much smoother and expanded sound. Even on a rinky dink CD.
Great upgrade for 30 bucks...
Post edited by VR3 on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited May 2008
    His name is William, he's a member here.
    VR3 Posts: 29,697
    edited May 2008
    Thanks for the info. I know WWW III is a member here :)
    Either way - excellent recomendation...
    Great sounding Tubes.
    JJ Tesla ECC802 12AU7 Preamp Tube Long Plates
  • RuSsMaN
    edited May 2008
    They are ECC82.
    VR3 Posts: 29,697
    edited May 2008
    Thanks.
    I just copied and pasted the name of the EBay auction...
    VR3 Posts: 29,697
    edited May 2008
    PS -
    Results were found after a 3 day warm up period.
  • dorokusai
    dorokusai Posts: 25,640
    edited May 2008
    WCWIII aka W WALDECKER. How did you get 14K+ posts again?
    VR3 Posts: 29,697
    edited May 2008
    You're witnessing it right now. Old guys with to much time trying to be a pain in my rear.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited May 2008
    "too" much time. . . no "to."
    Go back to school.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • dorokusai
    edited May 2008
    You rule Trey, don't forget that.
  • daboyz
    daboyz Posts: 5,207
    edited May 2008
    RuSsMaN wrote: »
    They are ECC82.
    Me thinks Trey was right on the #ECC802. As I was researching the tubes I found them.
  • organ
    organ Posts: 4,969
    edited May 2008
    daboyz wrote: »
    They're actually 82. The 802 by JJ is the gold pin version of the 82. It's not actually a true 802. The only difference would be the pins, not internals like the real 802.
    Sounds good Trey. Glad you're enjoying the tube rolling. Give them about 100 hours or so to open up. The JJ is my fav out of the current production tubes in the ECC82 family.
    VR3 Posts: 29,697
    edited May 2008
    Man - this is easilly the best 30 bucks Ive ever spent on my rig.
    I am listening to some jazz right now, and the instruments sound soooo good. Very smooth and textured. I like it.
  • Ern Dog
    Ern Dog Posts: 2,237
    edited May 2008
    Just for kicks I ordered a pair of these for my preamp. I paid $24 from Tube Depot. We'll see how they compare to the Jan Phillips I'm using now.
    VR3 Posts: 29,697
    edited May 2008
    The high end is so much cleaner with these tubes too. It no longer sounds "fuzzy" ya know what I mean?
    Its crisp, fast, and clean.
  • AndyGwis
    edited May 2008
    Tell Klaus to put those tubes in Candela's and sell them as "special edition" or "modded." He can charge 15% more for the ones with the Teslas; clients are happy cuz it sounds better than the stock/regular version, and you can tell him to split the proceeds with you.
    VR3 Posts: 29,697
    edited May 2008
    Man ---
    I never thought tubes could make such a difference. Just listening, general listening --- what a fantastic difference. Amazing detail.
  • Ern Dog
    edited June 2008
    The JJ Tesla tubes I ordered came in today. I popped them in with a couple tube dampers and it sounds a bit muffled and flat compared to my Jan Phillips. So they sound like crap brand new. I'll give it time to break in and will update this.
    They arrived very well packaged from Tube Depot.
  • dorokusai
    edited June 2008
    One mans' gold, is another mans' lead.
  • Ern Dog
    edited June 2008
    dorokusai wrote: »
    We don't know that for sure yet. It isn't fair to judge these tubes before they break in.
    treitz3 Posts: 20,276
    edited June 2008
    Did you send the Candela to Klaus? I thought it had a buzz issue or something?
  • organ
    organ Posts: 4,969
    edited June 2008
    Ern Dog,
    Try them without the dampers. Sometimes over-damping can make the system sound less lively. Also, the sound character of the JJ is very different than JAN Phillips tubes. Every JAN Phillips I've tried are more bright and edgy. JJ's house sound is very much like the NOS Western European stuff like Mullard. Warmer, darker, more laid back, etc.
    Hopefully they'll be more to your liking after some break in time.
