Mixing 4 ohm and 8 ohm Speakers?
VXR8
VXR8 Posts: 291
Hi all,
Help needed again :rolleyes:.
I am looking at purchasing an Emotiva XPA-5 and shipping it here to Sydney, Australia. No issues with this as I have been in contact with Emotiva, but in the short term, I will be running a 4 ohm and an 8 ohm load consecutively, until I complete my LSi system.
My mains are currently LSi9s (the 2 x 4 ohm speakers), my centre an older CS350LS and my surrounds the LSfx from the same series of speakers (the 3 x 8 ohm speakers).
1. Will the different impedances place any additional stress on the amp (any amp for that matter, not just the Emotiva) or will it be all OK?
2. Will this also change the overall output of the amp as it is seeing a different load for different speakers? As an example, the XPA-5 is rated at 200w x 5 into 8 ohm, 350w x 5 into 4 ohm etc.
3. Will it feed the 4 ohm speakers a maximum of 350 watts and the 8 ohm speakers a maximum of 200 watts, or come up with say 250w x 5 as a happy medium - strange question I know, but just need some clarity around this.
Thanks in advance as usual.
Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200
Post edited by VXR8 on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    No problems. Your good. Have fun.
    Ben
    Ben
  • Early B.
    Early B. Posts: 7,900
    edited May 2008
    Yep. No problem at all for any multi-channel amp rated to run 4 ohm speakers.
    I have an Emotiva LPA-1 and I'm running 8 ohm (fronts), 4 ohm (center), and 6 ohms (rear). Calibrate accordingly.
    "God grooves with tubes."
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2008
    as long as the flux capacitor holds your good.;)
    RT1
  • VXR8
    VXR8 Posts: 291
    edited May 2008
    Thanks Ben, Early and RT1 - just wanted to play it safe.
    I know F1Nut doesn't think the Emotiva are good amps (not a real man's amp in a recent post of his), but it appears to me that the overwhelming opinion is that these are a great bang for buck alternative to mainstream brands, that sometimes even outperform the "brand" names.
    Anyway, onto Emotiva today to place the order for the XPA-5. Thanks again guys for your input.
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • zingo
    zingo Posts: 11,258
    edited May 2008
    When I mixed 4 and 8 ohm speakers, my flux capacitor didn't hold, is that bad?
  • pietro944
    pietro944 Posts: 720
    edited May 2008
    zingo wrote: »
    one word.......Viagra
