Analysis plus bananas...
steveinaz
Anyone ever work with these? How are they crimped, on the thick rear sleeve? Doesn't seem right...
Post edited by steveinaz on
I use them all the time, the sleeve is actually pretty thin and crimps easily, easier then their spades do. -
So the thick sleeve is actually crimped...wow, that's some thick-**** metal. What crimp tool are using?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Some cheap one I bought at Radioshack, it was <$10 and has served me well for years.
Thanks man, appreciate the help.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
What size battery does that take?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
That's AudioQuest, not Analysis Plus with the bat pack.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I use a Klien crimper. They sell them at Home depot. They work great. I have some of those bananas. I shrink wrap after I crimp for a semi sealed Install.Dan
It was some vibrator humor Mr. Literal, but thanks.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I also have those and have ran all new wires in Analysis and used these. They don't crimp real easy unless you use the right tool. The sleeve is thick and I also shrink wrap the ends to make it look complete and clean. I have a ratcheting crimper that made the job awhole lot easier. Really nice connectors. What are you using for wire?
Dave -
I,for some reason thought these were a solder connection...can also be crimped?
Mike Reeter wrote: »I,for some reason thought these were a solder connection...can also be crimped?
They are crimp only, I would not solder these.
Dave -
It was some vibrator humor Mr. Literal, but thanks.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
dave shepard wrote: »They are crimp only, I would not solder these.
Dave
Thanks Dave,I didn't mean to imply that they weren't a "crimp" style.
I've been thinking of picking up some of these myself.
I have some Signal Cable wires with this connector,I like the way they fit over the standard nannars. -
Signal Cable solders them after crimping.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
