Analysis plus bananas...
steveinaz
steveinaz Posts: 19,546
edited May 2008 in DIY, Mods & Tweaks
Anyone ever work with these? How are they crimped, on the thick rear sleeve? Doesn't seem right...
Post edited by steveinaz on
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    steveinaz wrote: »
    I use them all the time, the sleeve is actually pretty thin and crimps easily, easier then their spades do.
  • steveinaz
    edited May 2008
    So the thick sleeve is actually crimped...wow, that's some thick-**** metal. What crimp tool are using?
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    Some cheap one I bought at Radioshack, it was <$10 and has served me well for years.
  • steveinaz
    edited May 2008
    Thanks man, appreciate the help.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2008
    What size battery does that take?
    treitz3 Posts: 20,088
    edited May 2008
    That's AudioQuest, not Analysis Plus with the bat pack.
  • mantis
    mantis Posts: 17,557
    edited May 2008
    I use a Klien crimper. They sell them at Home depot. They work great. I have some of those bananas. I shrink wrap after I crimp for a semi sealed Install.
    Dan
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    steveinaz wrote: »
    Anytime.
  • dorokusai
    edited May 2008
    treitz3 wrote: »
    It was some vibrator humor Mr. Literal, but thanks.
  • dave shepard
    dave shepard Posts: 1,334
    edited May 2008
    I also have those and have ran all new wires in Analysis and used these. They don't crimp real easy unless you use the right tool. The sleeve is thick and I also shrink wrap the ends to make it look complete and clean. I have a ratcheting crimper that made the job awhole lot easier. Really nice connectors. What are you using for wire?
    Dave
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited May 2008
    I,for some reason thought these were a solder connection...can also be crimped?
  • dave shepard
    edited May 2008
    They are crimp only, I would not solder these.
    Dave
    edited May 2008
    dorokusai wrote: »
    Whoops, that one flew over my head :o. Mr. Literal here. Over and out.
  • Mike Reeter
    edited May 2008
    Dave
    Thanks Dave,I didn't mean to imply that they weren't a "crimp" style.
    I've been thinking of picking up some of these myself.
    I have some Signal Cable wires with this connector,I like the way they fit over the standard nannars.
  • dorokusai
    edited May 2008
    Signal Cable solders them after crimping.
