A New Guru Among You
  • pearsall001
    pearsall001 Posts: 5,239
    edited May 2008
    Early B. wrote: »
    OK, but will you bend over? Gimme about two and a half minutes...;)
    You mean you still can't touch your toes!! :D
  • shack
    shack Posts: 11,154
    edited May 2008
    Early B. wrote: »
    No... but as a courtesy, I might bend over long enough to take a look and make sure you’re still breathing after I just knocked your **** out for making that "proposition". ;)
  • Frank840
    Frank840 Posts: 262
    edited May 2008
    Stay on topic keep your homosexuality out :)
    - This your Bush?
    Pioneer Elite Sc-25
    Polk Lsic,15's,9's, PSW1000
  • shack
    shack Posts: 11,154
    edited May 2008
    There is NO topic...:rolleyes:
  • audiobliss
    audiobliss Posts: 12,518
    edited May 2008
    ...and the sky...is a hazy shade of winter...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • engtaz
    engtaz Posts: 7,669
    edited May 2008
    Too hard to physically bow down soooooooo YES SIR is what you have to settle for. LOL
    engtaz
    engtaz
  • Early B.
    Early B. Posts: 7,900
    edited May 2008
    shack wrote: »
    Waaaaa!!!!:D:D
    Sorry, wrong guy. That "bend over" comment was intended for Russman.:o
    "God grooves with tubes."
  • shack
    shack Posts: 11,154
    edited May 2008
    Early B. wrote: »
    Waaaaa!!!!:D:D
    NO problem...have at it then...with Russ I mean...
  • Jstas
    Jstas Posts: 14,974
    edited May 2008
    Early B. wrote: »
    Listen up, you rat ****!! 'Cause I'm only gonna say this once....
    Now that I have elevated my consciousness to GURU status, here’s what you can expect from me:
    1. more audio snobbery just like my fellow gurus
    2. a lot more useless posts in order to acquire over 10K posts
    3. aggressive renegade behavior ‘cause now I’m above the “law” (i.e., Polk forum rules of conduct)
    4. less interaction with the newbs
    In return, I only expect one thing from you: total loyalty and obedience to the Early B. brand of bullst*t. If I say it, so shall it be. Amen.
    You are dismissed.
    That is a beautiful proposition....
    ...for me to **** on.
    Expert Moron Extraordinaire
  • Jstas
    Jstas Posts: 14,974
    edited May 2008
    MacLeod wrote: »
    Aint I special?! :D
    Oh, you're special alright! You're so special we should change your name to "Ed"!
