Polk LSi9 crossovers
AndyGwis
AndyGwis Posts: 3,655
edited May 2008 in Troubleshooting
Forum members - If anyone has an extra crossover for an LSi9, please let me know :)
I have a crossover with some damage on my LSi9s. If I were to order a new one from Polk, would it come with the 6 leads (1 +, 1 - for each driver) already soldered in and ready to re-insert into drivers? If it just comes with the board, I'm in trouble. I found out last night that my soldering is really terrible at best :)
Just FYI, I resoldered the part of the crossover that seemed to be damaged (separated from the board during a fall). It seemed to hold the coil as it should be. However, upon firing the speakers up, there was much more output from the good speaker, and it was much more clear than the one with the damaged crossover. The drivers seem to be in great shape on the damaged one, so I think if I get the crossover fixed/replaced, all will be well.
Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
Post edited by AndyGwis on
  • Face
    Face Posts: 14,340
    edited May 2008
    I would swap crossovers from cab to cab to make sure it is still a crossover, not driver problem.
    What kind of solder are you using? I find the cheap stuff doesn't like to stick to anything. Pick up some WBT or Cardas, it'll help.
  • AndyGwis
    edited May 2008
    To swap crossovers, do you unplug the 6 crossover leads (2 for each driver) from one speakers, and plug it in the other? I'm guessing it's a pretty easy thing, right?
  • Face
    Face Posts: 14,340
    edited May 2008
    Yes, just keep track of what goes where.
    Label them with tape, etc...
  • AndyGwis
    edited May 2008
    Okay, so I went ahead and ordered a new crossover. I didn't even get around to swapping them out. Unscrewing the back of each speaker, removing the crossovers, digging in to remove the 6 leads, remembering where they all went, swapping, and doing it all over again sounded like more than $50 worth of work.
    So, hopefully this brings the damaged one back up to specs. If not, I will be selling a "slightly used" Lsi9 crossover here shortly :)
    On the bright side, even with the $50, these were a deal (if they work correctly). And, with just the use of a black paint pen, I have them looking pretty respectable already as well. Just a scratch on the front corner, couple of rub marks on one ebony panel, a slight gouge on the back of the other ebony panel, and a scratch on the back. No biggie :)
  • criverajr
    criverajr Posts: 1,675
    edited May 2008
    Regardless, great deal. Glad someone here got them.
    CRj
  • AndyGwis
    edited May 2008
    Thanks for the heads up. Would've been gone already if I hadn't seen your post here.
    I tried them out again yesterday with the "repaired" crossover. I could only hear sound from the tweeter, so I guess the crossover is the issue. If the other drivers were moving but distorted or looked damaged, I'd be more concerned. The $50 crossover should make them whole once more.
    Again, thanks! Probably not much resale value in the damaged one, but a $400 working pair of Lsi9s ain't shabby. . . and they actually look pretty great after my touch-up work.
  • AndyGwis
    edited May 2008
    Thanks, that's what Ken S said as well. I've already felt around and marked what goes where, so install should be pretty simple.
    If anyone has pointers on installing crossovers in Lsi9s, lemme know! I think as long as I get the wires in the right place and don't break anything pushing in the crossover, I should be good.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2008
    The LSi crossovers come complete with wiring. It's easy but the biggest problem I had with my LSi15 was getting the mid-bass drivers out. They stick pretty good and are difficult to get from the rear. I used a hooked dental pick to get in between the driver and the cabinet for some leverage. DO NOT insert anything between the outside edge of the driver and the cabinet.
  • AndyGwis
    edited May 2008
    I don't plan on taking any drivers out. I already know which wire connects to which driver, so I'm just going to do it by feel from the inside. the only bad part is that the speakers are so deep that it's kind of a reach.
  • dorokusai
    edited May 2008
    Good luck with that.
