Denon VS Onkyo
xandra
xandra Posts: 291
edited May 2008 in Electronics
Am stuck in total indecision between the following Recievers:
Denon 3808ci
Onkyo 805
Onkyo 875
I've done a great deal of research, so you needn't waste time on spec comparisons...
I'm mostly interested in you're personal experience with: audio quality, manufacturer support, and user interface. (I tend to favor Onkyo for it's ease of use/interface but I've only had a few moments with the Denon-so not surprising i found it rather oppressive: example: had to go to submenus to select listening mode*)
Most importantly I'd like you opinions of
Audio quality differences between the Onk & Denon,
My main concern is music. (classical in particular, but also listen to oldtime Rock & R&B(Stones / Aretha) ie poor recordings.
I'm particularly interested opinions of those who've actually heard both models
or
2 comparable models from each maker ie a 120watt onk vs 120watt denon.
(I've tried for months to get to hear both with Polks to no avail...)
If you have any other opinions about the pros/cons (not specs) of these models... please speak up.
-* Is it easy to program universal remotes to get to Denon's menus/submenus?
LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
• 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
Post edited by xandra on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2008
    What speakers are you powering with it, that'll make a big difference.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited May 2008
    I have the PR-SC885P pre-amp, which has the same feature set as the 875, just no amps. So while it's not a direct comparison, I find the sound quality to be excellent, with a slightly warmer sound. The 875 will also give you the benefit of the REON scaler, if you need one. The scalers in the other two units are not comparable in quality.
  • xandra
    xandra Posts: 291
    edited May 2008
    Whoops... RTi10 Fronts, CSiA6 Center, RTi6 Surrounds (might add RTi4s for Surround back when I get an Amp)
    LR Setup:
    Parasound 2250 Amp
    NAD T585 (DVD/SACD)
    Plans/Fantasies:
  • xandra
    xandra Posts: 291
    edited May 2008
    William: Warmer than what? (Denon? Onk 805?)
    LR Setup:
    Parasound 2250 Amp
    NAD T585 (DVD/SACD)
    Plans/Fantasies:
  • mantis
    mantis Posts: 17,394
    edited May 2008
    basically the biggest difference is how different they sound. Both companies have issues and strong pionts. Denon is a more laidback and onkyo is more in your face bright if you will. Depending on you needs, both companies are good in general.
    Dan
  • margate21
    margate21 Posts: 105
    edited May 2008
    if u did not buy the amp yet u should consider getting the onkyo 805 and the sunfire 5channel- 5200 that is on sale..(some seen some posts with regards to it). i love it with my lsi's. although i have no previous experience with amps. but i have read the rt 10's are power hungry as well. just a thought.
    lsi 15's, lsi c, lsi f/x
    onkyo 805
    sunfire tga 5200
    toshiba - xa2
    panasonic bd30
    sony kdl40v2500
    svs sb12+
  • xandra
    xandra Posts: 291
    edited May 2008
    thanks for the heads up, I'm probably going to a 2channel amp - but decided to look into it at your suggestion: Alas, seems no authorized dealers in my area (Sunfire won't honor warantees from non-autho dealers) Who'd ya buy from?
    LR Setup:
    Parasound 2250 Amp
    NAD T585 (DVD/SACD)
    Plans/Fantasies:
  • VXR8
    VXR8 Posts: 291
    edited May 2008
    mantis wrote: »
    Considering the above comment on the 2 manufacturers, some will say the RTi10s are a tad bright and need taming (I had the 10s matched with a Yamaha receiver and it was a bit harsh for music). My vote would be for the Denon 3808, but do your utmost to listen to both if you can with the Polks - good luck.
    Regards - Gaz from the land of Oz
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    Cambridge Audio - Azur 851C - CXUHD
    Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
    SVS - PB1000 x 2
    Foxtel - iQ4
    Belkin - Pure AV PF40
    Sony K77A9G
    Front Room System
    PS Audio - Sprout 100
    Cambridge Audio - CXC S2 - CA752BD
    Sony - UBX800 4K BluRay
    Polk Audio - Legend L200
  • WilliamM2
    edited May 2008
    xandra wrote: »
    Warmer than the Denon's I have tried. I have not listened to the 805.
  • WilliamM2
    edited May 2008
    mantis wrote: »
    You obviously have not listened to any of the new upper end Onkyo's.
    billbillw Posts: 7,546
    edited May 2008
    The Onkyo 805 is not 'in your face' or bright. It is actually very neutral.
    Ultimately, the biggest difference between the Onkyo 805 and the Denon 3808 is the price and the networking capability. I feel that the Onkyo has a better amplifier section. The Denon has better preamp section with more 'tweakability' (w/ respect to bass management and levels) along with a few nice features like HDCD decoding. Mainly, it has all the network capabilities that the Onkyo does not.
    The Onkyo 875 is basically the 805 with improved (HQV Reon) video processing. If your sources do not have good upscaling or deinterlacing capabilities, then the 875 is worth considering.
  • WilliamM2
    edited May 2008
    Doesn't the 805 have seperate crossover frequencies for all channels, adjustable every 5hz (ie 35, 40, 45, 50, 55, etc.) and speaker level adjustments of .5db? The 875 and 885 do. Curious what other bass management tweaks the new Denon's have.
  • Marty913
    Marty913 Posts: 760
    edited May 2008
    WilliamM2 wrote: »
    I know you did not mention Video performance but the June issue of Home Theater magazine compares the Denon AVR-3808 and the Onkyo TX-SR875 from a video processing perspective. Might be worth reading if you're spending the money. All information is good.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • WilliamM2
    edited May 2008
    Marty913 wrote: »
    I'm not spending any money, I already have the PR-SC885 pre-amp. The Denon uses the old Faroudja video proc (known for macro-blocking), the 875 and 885 use the REON video proc, from all other reviews I have read, there's no contest, the REON is a better scaler.
    edited May 2008
    WilliamM2 wrote: »
    I believe the Denon has more flexibility in terms of being able to adjust the LFE level + or - and in smaller increments than the Onkyo's.
  • WilliamM2
    edited May 2008
    billbillw wrote: »
    Nah, they both go in .5db steps, and the Denon has 10 selectable crossover points up to 250hz, while the Onkyo has 15 selectable up to 200hz.
    Of course most subs have level controls as well, so you could really get just abut any increment you wanted.
  • xandra
    xandra Posts: 291
    edited May 2008
    quotes by billi:
    Could you explain the difference between Amp/Pre-Amp sections to me?
    As for the 875 Reon Processing -- I've mixed feelings as I've read that Onk's implementation is limited. currently my TV's teensy so upscaling etc not a big deal (even my 480i recordings which I further downsampled look ok). But who knows one day I may desired a 10' display) My main interest in the 875 is the extra HDMI port & a couple other fine points.
    (PS: HDCD's a nice format - wish it wasn't dead, but to date I only have 1 disc, - and my ancient Panny can decode)
    LR Setup:
    Parasound 2250 Amp
    NAD T585 (DVD/SACD)
    Plans/Fantasies:
  • WilliamM2
    edited May 2008
    The only limitation I am aware of on the Onkyo's REON implementation, was when they were first released. The REON picture controls were missing. This was corrected in the first firmware update last October.
  • mmadden28
    mmadden28 Posts: 4,283
    edited May 2008
    xandra wrote: »
    quotes by billi:
    Did you mean SACD?
    ____________________
    Pool: Atrium 60's/45's
    edited May 2008
    WilliamM2 wrote: »
    I'm talking LFE level, not sub level. Also, a limitation of the Onkyo is it only goes - in trim adjustments.
    This became an issue when people tried to workaround the Panasonic LFE bug on their bluray players. It was easier to fix on the Denons.
  • xandra
    xandra Posts: 291
    edited May 2008
    mmadden:
    No- I did mean HDCD (tho I love and rely on SACD in this case have a Yammie to decode- another great loss)
    Yes have heard this - following threads at avsforums - but seems upgrading dated units is at your own risk: thus I've been stalling hoping to receive an already updated unit (the latest apparently also fixes some lip-sync issues - more important to me)
    LR Setup:
    Parasound 2250 Amp
    NAD T585 (DVD/SACD)
    Plans/Fantasies:
  • mmadden28
    edited May 2008
    WilliamM2 wrote: »
    I have the Onkyo 805, with respect to the LFE levels and the use of the multichannel inputs (from an SACD), I've read that the LFE is typically sent to the reciever/preamp about 10dB lower than ideal and that a general suggestion is to turn up the LFE level +10dB on the multichannel input. The Onkyo 805 only allows you to set the dB levels per input to 0 (no change) or -10dB. So I was unable to just turn the multichannel level +10dB.
    The other more precision level controls you refer to are global and affect all the inputs. In the SACD's case (or is it any multichannel line level source?), bumping up the LFE there, will cause all the other sources to also be +10dB which is just too much. The only workaround I was able to come up with was to do just that, set the global level for LFE +10db, then set the 'per input' levels of all but the multichannel to -10dB.
    So it seems that yes you can get some precise control with levels, but to me, it was not straightforward, and actually the first couple times tweaking, I missed the availability of both sets of level controls-just a bit confusing.
  • mmadden28
    edited May 2008
    xandra wrote: »
    I don't have enough experience to really post a worthwhile comparison, especially since I am also using an external amp, I think the Onkyo 805 is a nice AVR. I chose it based on some of the specs, but mainly because it was generally posted to be a decent AVR, even if just used as a pre-pro. Besides I bought mine at ecost.com (auth Onkyo dealer) as a factory refurb fo rabout $570 (+/-)-The unit I recieved not only contained the remote and everything else they said referbs don't have, you could have fooled me that it wasn't a brand spanking new unit. It has a shorter 1 year warranty, but you can by an additional 1 or 2 (I forget) for $70 from Onkyo direct.
    I have RTi12s for fronts. I am not sure yet on brightness/warmth yet. It seems that with my constant tweaking and experimenting, that sometimes I get a bright harshness, and sometimes I don't-depends on the settings I had it set to. It's also varied considerable depending on my source (DVD, CD, SACD, Fios/Cable). (I'll avoid any talk of IC or speaker wire types here :rolleyes: )
    The only other annoyances I can really post about, might be when you change between different sound decoding options, there is a delay with no sound during the switch, so its harder to do any "on-the-fly" comparisons. Its also annoying when you go into the setup, that the source audio is disabled, so again, you can't make any on-the-fly sound or level adjustments. I don't recall what other AVRs do allow the on-the-fly adjustments, but they are out there. Definately a feature I wish this Onk had.
    Oh and if you have an Xbox 360 with component output, and you connect it to the component input on the 805 and output via HDMI, the output will only be 720p, essentially scaled DOWN. The image (especially the main Xbox Blade interface, (unless I have an isolated case) was also very washed out. I ended up connecting the Xbox directly to the component input on the TV to avoid the color wash and maintain the 1080i resolution. (Note: I have one of the early generation Xbox's-but not the first-thus I have no HDMI output option).
  • mmadden28
    edited May 2008
    billbillw wrote: »
    Note: I may have the LFE and sub levels mixed up in my previous comment-sorry I'm not in front of my HT right now to verify. As I mentioned-it was a bit confusing in that area.
  • mmadden28
    edited May 2008
    xandra wrote: »
    mmadden:
    Hmm, haven't heard that one before. So far for the consumer level HD type formats, I've only heard of SACD, the DVD formats using the audio portion (DVD-Audio), and of course the new HD-DVD/BluRay HD audio formats (Dolby and DTS varieties). And before I get yelled at, yes I've also heard of vinyl. ;)
    Learn something new every day/
  • WilliamM2
    edited May 2008
    Updating the firmware is a piece of cake on the 875, 885. With the 805 you would have to send it in, as they have not released firmware to end users.
    These units are sold out half the time, so most vendors have very fresh stock, I haven't heard of anyone getting a unit with the original firmware in at least 6 months.
  • xandra
    xandra Posts: 291
    edited May 2008
    mmadden wrote (refering to HDCD):
    HDCD was an audio format MS developed?/stole?/copyrighted? I dunno anything else about it, except that all HDCD disks are hybrids (will play std CD layer on any player) & how it sounds:
    I've one disk: "Crosby Stills & Nash Greatest Hits" if this CD is any indication - the format's a real winner. Tho not as sweet as SACD, It's the best quality I've heard from remastered music of this type & era.
    Alas, the format's dead - so if you don't have a player or disks, I wouldn't worry about it.
    LR Setup:
    Parasound 2250 Amp
    NAD T585 (DVD/SACD)
    Plans/Fantasies:
  • xandra
    xandra Posts: 291
    edited May 2008
    WilliamM2 wroteth:
    Thanks William - that's a deal breaker for me (at least between 805 & 875).
    Wonder why all the folks on avsforum are downloading stuff posted there?
    see thread named "The Onkyo/Integra direct firmware updates"
    http://www.avsforum.com/avs-vb/showthread.php?t=1016297
    If I decide against the Denon, I'm only left with choosing a dealer (I generally prefer Crutchfield for their excellent return policy, but for some reason they're MUCH higher on the 875.
    LR Setup:
    Parasound 2250 Amp
    NAD T585 (DVD/SACD)
    Plans/Fantasies:
  • kuntasensei
    kuntasensei Posts: 3,263
    edited May 2008
    The Denons let you select the target curve for Audyssey MultEQ XT. The Onkyos use the Audyssey curve no matter what (with a slight rolloff of the highs similar to THX modes). The only way to trick the Onkyos into using Flat mode is to switch to a THX mode and turn the THX rolloff off, but it's not a persistent setting. The Denon is more flexible in that manner.
    That said, I'm running an Onkyo 705 with RTi70 mains, CSi40 center and RTi28 surrounds with a SVS 20-39CS+ sub rig. I like the rolloff of the highs with Audyssey, since it tames some of the "sparkle" that the Polks had. It's especially noticeable with trumpets and violins. I don't think you could go wrong with either brand, but if you're concerned about having options for tailoring the sound to your liking, I'd go with the Denon.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • WilliamM2
    edited May 2008
    xandra wrote: »
    WilliamM2 wroteth:
    People download from AVS because it is much simpler, and quicker. Onkyo will send you a form to get the update, you have to sign it, fax it back, and then wait for the update CD to arrive in the mail. Although they do send some people links to download the DSP update. Don't know why the refuse to do that with firmware updates.
    B&H has excellent service, and the 875 is about $310 less than Crutchfield with shipping.
    http://www.bhphotovideo.com/c/product/484703-REG/Onkyo_TX_SR875B_TX_SR875_Home_Theater_Receiver.html
    J&R has also always given me great service, and it's $1099 + free shipping, $350 less than Crutchfield:
    http://www.jr.com/JRProductPage.process?Product=4192495
