Well...I just blew it...SVS sub driver gone Bye Bye
2
  • jakelm
    jakelm Posts: 4,081
    edited May 2008
    tryrrthg wrote: »
    That seems really big for a 12. was that what you were using for the SVS driver?
    What size port is it? unless it's a 6" port it's likely too small for a 15" driver.
    Another thing is, I built the enclosure with the intent of putting the SVS in the smaller 3ft3 enclosure, that I built and putting a larger driver in the big tower. But never got around to doing it until now.
    I call it a tower, 18"D x 17"W x 44.5"H.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • tryrrthg
    tryrrthg Posts: 1,896
    edited May 2008
    The big box probably led to the SVS destruction also... oh well, now you can go big!
  • jakelm
    jakelm Posts: 4,081
    edited May 2008
    tryrrthg wrote: »
    That.. and the fact that the voice coil was slamming into the back of the magnet...lol
    All I was doing was trying to make that last pot in my cabinet fall...damnit!!.
    It didnt fall either...:mad:
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • shadowofnight
    shadowofnight Posts: 2,735
    edited May 2008
    jakelm wrote: »
    Shadow, my amp was set to 20hz-medium.
    It wasnt because of the driver or the amp. It was because of me...
    I was fooling around with level settings, and paused the movie on a certain spot to listen and relisten and make adjustments. I did a multiple of stupid things, raising the gain on the Rythmik amp , to get peak output w/out distortion and ASSuming that I was raising the level of the center channel, to adjust for imbalance.
    Started playing the movie and WWWAAAMMMOOO.. It really rocked the house for a good 2 seconds, before I could get to it.
    Anyways... OOOOOPPSSS!!.. My bad, now I just have to replace and have more fun callibrating a new sub.
    Haha....dont feel bad...you are not alone. I was at a buddies house and we had just finished a pair of TC Sounds TC-2000 passive radiator designs using TC Sounds own 15" passive radiators ( 6 Cu Ft each cabinet ...1 TC-2000 and 2 TC VMP's per cabinet....tuned to approx 20Hz using different washer counts on the PR's )
    Had his place ROCKING to the flick Live Free or Die Hard......the spot where the bad dude falls down the grinder...some serious LFE there....especially on Blu Ray in DTS-HDMA...and after all the calibrations had been done....you could feel the blasts kicking your chest in :)
    Well he paused it and went to adjust the B-1's main level a LITTLE bit I told him ...just to push the subs even more to see what they were really capable of...and he didnt realize the little bit he chose was like 5 or 6 clicks on the B-1 on the left sub.
    He undid the pause and you should have heard that TC bottom...it cold formed the aluminum cone instantly...he lunged for the B-1 but it was too late. Funny thing is...the TC took it in stride...it still sounded perfect when adjusted back where it was calibrated at.
    He replaced the driver with another TC and just gave me the cold formed one to experiment with....I put it in a little cheap but well braced 2 Cu Ft sealed enclosure and it will take the full output of a bridged RF2000 ( 1,200 watts into 4 ohms ) sounding absolutely wonderful :) Basically the cold forming of the cone raised the voice coil approx 1/8" ....I pulled the motor to see the condition of the VC....it was no different then one of my own TC-2000 top assy's. Thats got to be one of the toughest VC formers I have ever seen.
    Even though the vc is positioned a tiny bit higher...it still functions normally ( Measures no differently then my driver ) ...amazing. I will take a shot of the driver in a few minutes. :)
    The first rule of Fight Club is you don't talk about Fight Club
  • shadowofnight
    edited May 2008
    I just snapped these pics.....the 3 of the sub alone are the pooched cold formed TC-2000....the one pic with the gear is what that TC-2000 driver SHOULD look like :p
    I just bought that cheap little 2 Cu Ft carpeted enclosure ( I did brace the hell out of it though...prob used up .5 Cu Ft. in bracing alone...along with the driver the actual useable area inside is around 1.4 Cu Ft. taking into account the acousta fiber fill as well ) to test out the driver.
    The TC-2000 in the pic with the gear is in a very nice 3 Cu Ft sealed enclosure from PE http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=302-820
  • jakelm
    jakelm Posts: 4,081
    edited May 2008
    Tempest - X is the one I'm jumping on...
    I was very close to getting the Creative Sound, but the specs on the T-X compared to the CS does not justify the extra $100
    And I guess I can always cut a fellow Polkie a geat deal if the T-X doesnt work out.
    Thanks for all the help fellows..
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • devani
    devani Posts: 1,497
    edited May 2008
    now for the review~~ let us know how you like it
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • jakelm
    jakelm Posts: 4,081
    edited May 2008
    Will do./..
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Systems
    Systems Posts: 14,872
    edited May 2008
    jakelm wrote: »
    Good choice.
    Testing
    Testing
    Testing
  • jakelm
    jakelm Posts: 4,081
    edited May 2008
    Thanks GV, it should be here by the weekend,
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • deep bass
    deep bass Posts: 86
    edited May 2008
    Jackhammer?... J/k
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    Well Jake I have been biting my tongue for too long. You need to control yourself brotha:D
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited May 2008
    Ha:p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited May 2008
    Do I need to crack the whip like you did when I was building my big SDA's;)
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited May 2008
    ben62670 wrote: »
    No use, my freind...I'll probably blow this one too, sooner or later...:D
    ...save the whip:p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited May 2008
    So we are at 1 and 1 for destroying heavy duty subs!
    I'll be watching...
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited May 2008
    ben62670 wrote: »
    I'll be watching...
    In the "heavy duty" class, yes...but not my first sub to snap crackle pop...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Deadof_knight
    Deadof_knight Posts: 980
    edited May 2008
    I call it smoke testing !
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • jakelm
    jakelm Posts: 4,081
    edited May 2008
    Well. It came in last night. This driver is big and heavy, 36lbs. The output is as much or more than the 2 12's I had running before. I didnt measure it yet, but just by listening to it, I can tell, the sub clearly out performs the SVS (in my enviroment). It could be the fact that the Tempst was built to enjoy alot of airspace, or it could be because of the increase in size. Reguardless of the reason, there is no more need for 2 subs. The Dayton 12 will be either sold or given to my cousin for his, starter surround system.
    Like I said earlier, the driver is heavy. I have it down firing, screwed onto a single 5/8 partical board. I will double the bottom of the cabinet. No "chuffing" from the 4" port, but I have not pushed the sub hard yet. Didnt realy have to. Being the driver is bigger the amp doesnt have to drive the woofer as hard to produce deep low bass.
    I was dissapointed that the SVS was destroyed due to my mistake, but things happen for a reason and I am now even more satisfied with the new driver. The SVS had to really move to produce the bass I wanted, with the new 15" driver, everything moves and sounds alot smoother now.
    Extreme testing will come in the near future. Transformers and Beowolf, will be the tester.
    I also plan to run the REW, to see the overall performance. But just by listening, I am pleased........
    ...for now...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited May 2008
    Pics buddy. We want pics!
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited May 2008
    ben62670 wrote: »
    Ok..I'll try to get some.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    Well guys, I have been fooling with this damn sub for over a week now, trying to get it right.
    My first project was 6.5ft^3 ported, tuned to 18.5hz. After running the sub for awhile, I discovered a major spike @ ~ 38hz. I emailed DIYcables, asking what was the optimun size enclosure for the Tempest. My calculations came out to ~ 9ft^3. Too big for what I wanted to build. DIYcables advised me, if i were not going to build such a large enclosure, that I should stuff it and seal it. So thats what I did. 6.5ft^3 stuffed and sealed. On paper (WINisd), it specs out just fine. But after running REW room EQ, the 38hz spike was still present.
    Anyways, the output is amazing. Watched Cloverfield and was amazed (even with the +/- 4db ~38hz).
    I also took a few shots of the size difference between the Tempest and the SVS.
    .....I am continue to work on the 38hz spike, trying to avoid a sub Eq.
    P.S. Pay no attention to the date on the pics. Cam was not set.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    More....
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited June 2008
    Thanks for the pics buddy. What meter are you running for spl? Remember that a lot of Mic's/meters need calibration down low, and of coarse room gain.
    Ben
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    ben62670 wrote: »
    Ben
    No problem:)
    I use the rat Shack meter. REW from TheTheatershack, has a pretty accurate peice of software that installs with REW to compinsate for the RS meter's inacuracy down in the lower HZ region.
    Remember that the SVS driver was in the exact same inclosure. In the exact same spot in the room. There was no spike @ 38hz with the svs. So I know its the Tempest.
    But just for the record. The Tempest way outperforms the SVS. (The older SVS driver, at least)
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Systems
    edited June 2008
    jakelm wrote: »
    No problem:)
    You can tell if it is a room induced problem or the sub itself by doing a nearfield measurement of the sub.Placing the meter within a few inches of the driver while doing the measurement will greatly reduce or eliminate any room modes in the measured respone.This is best done away from room corners.If the peak still exists then it is the sub not the room.
    not surprised,thats a great driver , I only wish I could afford one.:(
    Testing
    Testing
    Testing
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    Cant change anything in the room (WAF), so I'll just have to deal with it another way.
    I had it front firing at a 2nd and 3rd try, but found down firing to be the best.
    1st: Down firing, ported. Sound wqas a tad floppy.
    2nd: Front firing, ported. Localized floppyness
    3rd: Front firing, sealed. Better, tighter sub. But still localized.
    4th: (Final) Down firing, sealed. Best.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    Can you believe, the Tempest's optimal enclosure is 10-12ft^3?
    OUCH!!..Talk about theater sub. They ment it literaly.
    And I thought I had an above average size enclosure, thats almost twice the size I have.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Systems
    edited June 2008
    jakelm wrote: »
    My comment about moving the sub away from the corner was just to make the near field measurement of the sub with out the rooms influence.Then put the sub back in its corner.
    Testing
    Testing
    Testing
  • Systems
    edited June 2008
    jakelm wrote: »
    My comment about moving the sub away from the corner was just to make the near field measurement of the sub with out the rooms influence.When measurement is done put the sub back in its corner.
    Testing
    Testing
    Testing
