Integrated Tube Amp Suggestions
janmike
janmike Posts: 6,146
edited May 2008 in Electronics
I am still and probably will be for years to come toying with the 2CH thing. Right now I am contemplating looking at a nice integrated tube amp. The Audio Research thing is a little far out at the moment. Anyway, I wanted to tap the knowledge bank of you tube "gurus" for suggestions on a nice integrated unit that I may consider.
Here is what I think would like:
Minimum of 100 wpc - 8 ohms (I am thinking Class A)
Balanced Inputs (I already own good balanced cables)
Comparable to lines in Audio Research like (LS26 & VS110)
I know NOTHING about tube gear, but want it for matching purposes. As for price, not really a huge issue as the ARC gear will run me $8K to $10K for used gear.
Thanks for the help.
Michael ;)
NORTH of 60°
Post edited by janmike on
  • george daniel
    george daniel Posts: 12,096
    edited May 2008
    I was gonna' say,,Manley Stingray or Rogue Cronus,,until I read the part about 100 watts/channel. I think that the Rogue puts out about 50-60IIRC,,good luck.:)
  • janmike
    edited May 2008
    Thanks George. I reason I indicated 100 wpc was trying to compare it to the ARC gear I was looking at. Perhaps a little lower may do the trick. That Manley I remember from Polkfest last year. NICE!
    Michael ;)
    NORTH of 60°
  • SolidSqual
    SolidSqual Posts: 5,218
    edited May 2008
    I owned th Cronus for a while and was extremely pleased with its performance. I ran a pair of Totem Mode One (non signature) with it. The sound was excellent. I'm actually looking to find a smaller rig like that as well.
  • Face
    Face Posts: 14,340
    edited May 2008
    Zero wrote: »
    Jan,
    Get set of the new McIntosh 301 mono's and top it off with the MC2300 pre and call it a day.
    100 watts of tube power? Is this just for giggles? Why on earth do you need this - did your heater in the house die? Unless you're running extremely difficult speakers in a HUGE space - this is massive overkill and will be a waste of resources.
    Well, he is from Canada. It would probably cut his heating bills in half during the winter. :D
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited May 2008
    I've never had a tube int. so I'm biased ;)
    I would recommend a carver ss amp for about $500 or less and then a good tube pre for about $500.
    Don't worry about keeping the balanced cables. Good cables can be had for about $100.
    carver m1.5t $399: http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1215354468
    cj pv-7 $799: http://cgi.ebay.com/Conrad-Johnson-PV-7-Preamplifier-just-back-fr-factory_W0QQitemZ180241900586QQihZ008QQcategoryZ12050QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • janmike
    edited May 2008
    Zero wrote: »
    Jan,
    No, actually it is based on MANY people's recommendations that paired up the speakers I will be using (Proacs, which are easy to drive) and the Audio Research gear. Proac voiced with ARC for years. The amps that folks have used all have 100 wpc - Class A tube.
    BTW - I love the look of McIntosh.
    Michael ;)
    NORTH of 60°
  • Face
    Face Posts: 14,340
    edited May 2008
    http://mcintoshlabs.com/products/1007.asp
    It's rated at 75wpc, but as with the rest their gear, it's under-rated. I heard it's actually closer to 90wpc.
  • janmike
    edited May 2008
    Zero wrote: »
    Janmike - I've alwayed like Acoustic Research. I wonder how their hybrids sound... hmmm..
    Not sure about Acoustic Research but Audio Research is highly regarded.
    Michael ;)
    NORTH of 60°
  • SolidSqual
    edited May 2008
    acoustic research is sold is best buy?
  • dorokusai
    dorokusai Posts: 25,638
    edited May 2008
    Acoustic Research is sold in BB, not Audio Research.
    Zero - You should be ashamed of yourself.
  • SolidSqual
    edited May 2008
    Don't worry about it we all knew what you were saying.
  • janmike
    edited May 2008
    SolidSqual wrote: »
    Exactly. I did a 360 when I first read it and then said, I know what he meant. Perhaps I should just do without until the ARC gear becomes a reality.
    Michael ;)
    NORTH of 60°
  • 92135011
    92135011 Posts: 2
    edited May 2008
    hmm I thought true class A single ended usually exceeds no more than about 25W per channel. I run 8 watts single ended triode and its plenty loud. It's all in the efficient speakers I say (~94db/watt).
  • sucks2beme
    sucks2beme Posts: 5,701
    edited May 2008
    92135011 wrote: »
    Audio Research tube amps are "enhanced a/b". Whatever that means.
    It sounds good, that's all I care about!
    Integrated tube amps are normally 50 watts or less. AR vsx55, 50wpc,
    PrimaLuna Prologue two, 40wpc, ETC.
    I do see a Jolida Jd100rc thats 100 wpc. That one looks like a beast.
  • janmike
    edited May 2008
    Thanks folks for all the help. You people are great. I believe a decision has been made.
    Michael ;)
    NORTH of 60°
  • SolidSqual
    edited May 2008
    janmike wrote: »
    Well Jesus pal, tell us the good news.
  • marvda1
    marvda1 Posts: 4,971
    edited May 2008
    take a look at this ayon 100 watt amp or the 50 watt spirit integrated.
    http://cls.audiogon.com/cgi-bin/cls.pl?intatube&1216329556
    http://www.usatubeaudio.com/ayon-spirit.php
    Puritan PSM156
  • janmike
    edited May 2008
    marvda1 wrote: »
    Those do look nice for sure.
    SolidSqual wrote: »
    I pulled the trigger on an Audio Research LS26 Pre. Enough of this waiting stuff.
    Michael ;)
    NORTH of 60°
  • SolidSqual
    edited May 2008
    Excellent! Audio Research pre and CDP . . . any amps we don't know about?
  • janmike
    edited May 2008
    The ARC VS115 Amp is the next to come. I need save some more pennies as the jar is just about empty.
    Michael ;)
    NORTH of 60°
  • sucks2beme
    edited May 2008
    janmike wrote: »
    That is one VERY nice amp.
  • janmike
    edited May 2008
    sucks2beme wrote: »
    It is a very nice look piece for sure. I need to be patient. I have heard that it smokes the VS110.
    Michael ;)
    NORTH of 60°
  • dorokusai
    edited May 2008
    No, it doesn't.
  • sucks2beme
    edited May 2008
    dorokusai wrote: »
    No, it doesn't.
    I would love to have either sitting in the bottom of my audio rack.
  • janmike
    edited May 2008
    dorokusai wrote: »
    No, it doesn't.
    Well that is coming from many people who have owned both.
    Michael ;)
    NORTH of 60°
    treitz3 Posts: 20,276
    edited May 2008
    janmike wrote: »
    If I may, what made you make the decision to go that route? Congrat's on the 2-channel! :D
  • dorokusai
    edited May 2008
    janmike wrote: »
    I'm sure it is.
  • janmike
    edited May 2008
    treitz3 wrote: »
    I wanted to mate my Proac speakers with gear that was proven to have great synergy. Proac and ARC used to voice together and of the probably 50+ people that I have talked to over the years, more and more people liked the team of Proac & ARC. The tubes are definitely required for Proac speakers (although there will be some that say SS works) and the vote went to ARC due to the response that I received when asking questions. I heard the Proac 2.5 speakers with Cary 805C's and that was real nice.
    A well known dealer in Milwaukee (Ultra Fidelis) talks very highly of the VS115.
    Michael ;)
    NORTH of 60°
  • janmike
    edited May 2008
    Mark, I would be interested in hearing your assessment of the ARC VS110 versus the VS115. What Pre was being used and what speakers.
    Michael ;)
    NORTH of 60°
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited May 2008
    Ah, the AR sound....
