B&K Ref 30 lost sound signal
MKZ
MKZ Posts: 1,068
edited May 2008 in Electronics
It lost the sound whenever I change the TV channel. I need to change the mode to get the sound back. I connected the TV with optical cable. Thanks for any helps.
Post edited by MKZ on
  • dorokusai
    dorokusai Posts: 25,638
    edited May 2008
    Do a factory reset.
  • MKZ
    MKZ Posts: 1,068
    edited May 2008
    How? memory back up/restore?
  • MKZ
    MKZ Posts: 1,068
    edited May 2008
    Found it in manual. Thanks.
  • MKZ
    MKZ Posts: 1,068
    edited May 2008
    Happened less but still have an issue. It makes me throw the remote whenever flipping the channels. Surround mode should detect the signal automatically?
  • dorokusai
    edited May 2008
    Connect the TV with coaxial and see if the problem goes away.
  • MKZ
    MKZ Posts: 1,068
    edited May 2008
    Thanks. Let me try.
  • MKZ
    MKZ Posts: 1,068
    edited May 2008
    My TV doesn't have digital coax out :(
  • dorokusai
    edited May 2008
    Just use analog RCA, who cares about digital.....it's troubleshooting man.
    treitz3 Posts: 20,275
    edited May 2008
    Do you realize that the surround signal doesn't happen with every channel? Only those channels that support that kind of format does it happen with.
  • MKZ
    MKZ Posts: 1,068
    edited May 2008
    dorokusai wrote: »
    I thought about it. I need to go get 6ft long. Thank you.
  • MKZ
    MKZ Posts: 1,068
    edited May 2008
    treitz3 wrote: »
    With optical?
