B&K Ref 30 lost sound signal
MKZ
It lost the sound whenever I change the TV channel. I need to change the mode to get the sound back. I connected the TV with optical cable. Thanks for any helps.
Post edited by MKZ on
Do a factory reset.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
How? memory back up/restore?
Found it in manual. Thanks.
Happened less but still have an issue. It makes me throw the remote whenever flipping the channels. Surround mode should detect the signal automatically?
Connect the TV with coaxial and see if the problem goes away.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Thanks. Let me try.
My TV doesn't have digital coax out
Just use analog RCA, who cares about digital.....it's troubleshooting man.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Do you realize that the surround signal doesn't happen with every channel? Only those channels that support that kind of format does it happen with.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I thought about it. I need to go get 6ft long. Thank you. -
With optical?
