Power Cables
MKZ
Which one do you recommend? I intended to use with an amp. Please specify.
Post edited by MKZ on
I really like their Punch cable for the price. Also check out the Acoustic Research cable at Partsexpress; it's a great budget cable for a good price.
I vote either, both are great cables. The SC is as hardcore as it gets, imo. The PS Audio are more flexible, if routing the cord in a tight space is an issue.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
what price range are you calling cheap?
i was told once by the maker of some expensive power cables that most of the power cables in the lower price ranges are built around the same recipe, so buy from the one with the best price.
at the time i was asking about signal, element, and zebra cable.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I threw down for Other, as I wasn't sure what cheap was. I got a bunch of Volex 17604s for <$10 each. 6ft 14 gauge wire, well shielded with relatively tight fitting connectors. I use the originals with better quality wire and brass connectors on my amps, cheaper ones on everything else.
Both PC's are good. Of the two, I prefer the PS Audio for an amp but I don't know which model/series/year you are referring to, so take that with a grain of salt.
I voted "other" because I have had positive results with Analysis Plus Copper for amps. Actually, subs [with amps] and amps. Very pleased with the performance there.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
This is my 1st power cord upgrade. Is there any noticeable difference? Please educate me. I think I can't go wrong with either of those. Thanks for the replies.
Agree with others. PS Audio and SC are good value for the $.Michael
NORTH of 60° -
I use the SC's. Magic Power for my amp, Magic Digital for the preamp and source. Frank is a great guy to deal with, I highly recommend...Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
What about this? I couldn't find in AudioQuest site. DIY?
http://cls.audiogon.com/cgi-bin/cls.pl?powrcabl&1214086045 -
Another vote for Signal Cable. I'm lovin mine, and Frank rocks.
I was going to suggest making one yourself, but you'd be hard pressed to build a decent one for that price.My equipment sig felt inadequate and deleted itself. -
That's what I was thinking on other thread. For $60~70 I think I can get better cable with wattgate and neotech or vh audio. But I think I might go with either signal or ps audio if I couldn't find used good one.
What do you think about that AudioQuest for Pre/Pro since it is 15AWG thick wire instead of Signal Cable $70 digital reference. -
If you want the Signal Cable digital reference, I think I have one in the goodie box that I'm not using. $45 smackers to your door if you haven't already made a purchase.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Signal Cable.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Thank you all for the input.
I just bought Signal Cable Magic Power, Magic Digital reference and will also DIY with Neotech 3003 and Oyaide connectors in case you would like to know. -
Thanks for the offer teritz3. I just bought it. You should have told me a little earlier. I missed a great deal. -
PS Audio Statement power cords are excellent. They present a smooth overall sound with great bass punch. I find the Signal's to be edgy. YMMV.
The Statement's are not what one may call cheap, but not bad if you buy them used.Political Correctness'.........defined
President of Club Polk -
Nice thread, I was wondering this too, thanks for all the input everyone!
MKZ, you should be very happy with the signal cable digital reference power cable. I just added one to my Denon player and noticed immediately that on 2-channel playback, the highs had smoothed out (not harsh anymore). Unfortunately, the power cables are built-in on my pre and pro amps so I can't replace those without a DIY job and I'm not into that.
I'm tempted to buy the one that Treitz has for sale and swap out the cheap power cord I'm currently using on my projector.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
Which Oyaide connector are you planning on using? I have experience with a couple maybe I can help in choosing one depending on what you are after.
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
I already bought P/C-029. Thanks Mike.
MKZ, do I understand correctly that you bought the digital reference power cable and are swapping out both of the connectors? Where did you get the P-029?____________________________________________________________
Be careful with the Oyaide hardware!! There are a lot of Chinese counterfeit hardware out there. I have heard of tales of fake hardware being bought on eBay and Audiogon. A lot of info out on the web.Carl
Nice power cables can be had at audiogon via hcmaudio. Special audiogon only price. Audioquest AC15 H/W 2.3 meter for around $50-55 shipped. a little light for a heavy weight high powered amp, but for everything else, a deal indeed. Just bought one for my headphone amp power supply.[
Sorry Doug, I made you confused.
I bought Signal Magic Digital Reference for processor and 2 Magic Power for Amp and Subwoofer. I bought P-029 off the eBay and it possibly turns out to be imitation. I bought Neotech from SonicCraft, hope it is legit. I was planned to DIY just to compare with Signal how it goes. I have no equipment to use with. -
Thanks for the heads up Carl, it is very possible. I think I better go with Furutech. Do you know where I can get those? SonicCraft or VH Audio? -
I thought about it but Signal seems to be better since it has lots of rave and reviews and 15AWG vs 12AWG IMO. The connectors alone cost more than $30.
