Eh guys slight problem here.
Hello all;
I was watching ALIEN resurrection earlier on today quite loud ,and I kind of broke my subwoofer. As you can see from the pics I sent the coil so far it went out the magnetic gap and hit the magnet. Its kind of stuck. The driver is 550wrms and 1100w peak I was delivering 1000wrms. I know I should have seen it coming. Oh well looks like a chance to build a new sub .:)
ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
Post edited by ward91 on
Bummer - then again this is one of the few hobbies there are where, when something breaks, it is an opportunity to upgrade.
Good luck with your new sub. Looks like you need to invest in a 15" or 18" this time..
Awesome.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
So what was "quite loud"?Michael
NORTH of 60° -
is that a compressor?? is your PA rack doing some double duty? lol
agear list:
1 down, 4 up.... -
How do you know you were delivering 1000wrms? Is there a meter somewhere?
honda cber wrote: »is that a compressor?? is your PA rack doing some double duty? lol
a
it is, i use my pa amp and graphic eq for my sub, the eq allows for more gain and a real thumpy bass, i should really have cut 25hz (i usually doo)as this is "subsonic" and would most likely prevent over excursion. i dont use the comp at home.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
maximillian wrote: »How do you know you were delivering 1000wrms? Is there a meter somewhere?
no your right i dont actually know but;
my power amp is rated at 500wrms per channel at 4ohm which is what impedance my 4ohm per coil (2 coils) sub is/was.
The amp is also likely to have hit "clip" so it will have been over 1000w. The sub is 1100w peak so to over excurd (sp?) it I would have to be driven over 1100w?
I know that sub bass/ bass below 40hz can oven leads to over excursion in woofers (in the pro world) but this woofer stated nothing about cutting sub bass, and it is meant to handle bass (I think) .ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
Did you pull the spider up like that or was that as found ? The bottom edge of the spider looks too clean....like the glue all pulled off in one clean motion.
Sure you exceeded xmax....hell you even exceeded xmech....but that is the cleanest spider I have ever seen in that respect...most of the time the glue is stronger then the spider material itself and a lot of the spider is left shredded on the edge.
At least you killed it with style
The first rule of Fight Club is you don't talk about Fight Club -
That's impressive, Trooper !
I don't know how your "4 ohms per coil/2 coil" sub is wired: are those coils in Parallel or Series ?
In Parallel, you're talking 2 ohms and you might be giving your amp a hernia.
Sorry for your sub loss, but thanks for posting those pics.Sal Palooza -
i am only guessing, but with the power amp mentioned, he is probably running---- well, WAS running--- the sub in "stereo" (even if it is summed to mono somewhere). most amps like that can do 2 ohms per channel all night. bridged is a different story, however. for example, my mackie FR-M800 is rated at 275wpc 4 ohms and 400wpc 2 ohms. but bridged, the rating is 800w into 4 ohms, and 2 ohms is not recommended. i never bridge it, but often run 2 ohm loads for hours at a time.
agear list:
1 down, 4 up.... -
shadowofnight wrote: »Did you pull the spider up like that or was that as found ? The bottom edge of the spider looks too clean....like the glue all pulled off in one clean motion.
i found it like that, just took the woofer out and took some pics.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
i ran my amp in "stereo" 4ohm per side on the amp.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
I just finished one of my TC Sounds subwoofers this week , and I am using one of my bridged Rockford Fosgate RF2000 amps with it. Bridged into 8 ohms its 600 watts per channel...bridged into 4 ohms its 1,200 watts per channel .....the sub is a 4 ohm load ( 4 ohms is the lowest recommended ohm load to run bridged...thats basically a 2 ohm per channel load on the amp while bridged )
I am using every bit of its BL linear one way 30mm xmax ....staying away from the one way xmech of 46mm
Did you at least say in a proper scooby doo tone " Rot Ro Raggy "
Im not a pyromaniac. i just like fire.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
By gawd, there isn't anyone who can say that you don't have style !
... maybe not the best luck, but ..... that was good !Sal Palooza -
