Surroundbar/PWS 10 problem with Onkyo 705
imj
imj Posts: 2
edited April 2008 in Troubleshooting
I just got my surroundbar and pws10 subwoofer today. I connected them to my Onkyo SR705 receiver using the wire provided with the surroundbar. Plugged everything in and started it up. Volume at 35 (on 0-100). Great sound for about five minutes. Then I got a pop and my receiver shut off to stand by mode. I can turn the receiver on and it kicks off again if the cable box (wired via HDMI to the receiver is on). If I set subwoofer to no, I get sound, but can't get anything from the PWS10.
Help!!!!
Post edited by imj on
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2008
    Check your wiring, it sounds like a short.
  • imj
    imj Posts: 2
    edited April 2008
    I checked all the wiring and there was a frayed section in the subwoofer cable. I replaced it and it sounds perfect. Thanks for the help :)
  • dorokusai
    edited April 2008
    Sweet!
