Adcom GFA-5802?
twochannel
twochannel Posts: 170
edited May 2008 in Electronics
Does anybody know if the 5802 is a common grounded amp. I have a pair of original SDA-SRS's and I'm thinking of buying one to replace my mono blocks because they do not have balanced inputs and the conversion kits for them are no longer available.
Post edited by twochannel on
    heiney9 Posts: 25,629
    edited August 2006
    It is NOT common ground. This amp uses secondary windings. It's not compatible with certain SDA's. I believe if you search there is a thread, and the negative posts can be connected. But don't take my word for it, call Adcom or search the thread for a difinitive answer about the negative posts.
  • twochannel
    edited August 2006
    Thanks for the information. I have the negative posts connected on my 565 mono blocks as Adcom advised. I saw the information on the their website about the secondary windings on the 5802, so thats the reason for my question. The 5802 has been sold, so I will contact Adcom to see if i can connect the neg's, if another one becomes available.
  • twochannel
    edited April 2008
    I finally located and purchased a preowned Adcom GFA-5802 to audition on my SDA-SRS. I'm very picky about my components and this amp is in mint/low hours condition and was previously delivered to Boston Acoustics according to the shipping label on the box.
    WOW! After several weeks of use I have decided to retire my GFA-565 mono's and have started auditioning balanced interconnects. I am currently using Audioquest King Cobra's. There are some trade offs between the 5802 and the mono's. The 5802 has a greater depth to the soundstage using either single ended or the balanced inputs and the soundstage width is somewhat narrower with less effects to the outside of both speakers. The 5802 also seems to tame down the sl2000 tweeters.The opposite is true with the 565mono's. I have also compared the 555mkII to the 5802 and have found that the width of the soundstage is the same, the depth and bass response is greater with the 5802. The only issue I ran into is a bandwidth problem using single ended interconnects between the 5802 and the GFP-750 preamp that I am currently using. Adcom tech recommended going to balanced cables and it eliminated the noise issue.
    edited April 2008
    I'm an big fan of Adcom equipment and the GFP-750 and GFA-5802 is a formidable combination. You probably already know but both pieces were designed by Nelson Pass and the 5802 is a Mosfet amp vs. the older Adcoms being Bi-polar based.
    Enjoy as it doesn't get much better until you spend a lot more $$$ on components and even then sometimes the extra cost isn't worth it.
  • twochannel
    edited April 2008
    I believe their are some new pieces about to be introduced. The 5802 was discontinued 2 years ago with nothing to fill that slot in the product line. I could not get any information from the Adcom Tech Rep other than the wait and see attitude.
    edited April 2008
    twochannel wrote: »
    Yeah well, Adcom is barely a shell of it's former self and I really don't expect anything groundbreaking from them. I fear they will be taking a few steps back and become average and mediocre. The company has been sold several times and the current conglomerate that owns them doesn't seem to keen on keeping up the Adcom traditions.
    I hope I am wrong, but it is the state of the audio market today. Nakamichi just melted away to nothing and they were once on the leading edge.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited May 2008
    twochannel wrote: »
    I am resigned to the fact that Adcom has seen its best days. The management, technical staff, and "giant killer" mindset that put Adcom on the map are long gone.
    I ran my SDA's for several years with a GFP-750 pre and GFA-5802 amp combination. I still have some remorse about selling them, although if I hadn't, they would just be taking up space in my audio closet.
    I have also owned the GFA-565 monos and the GFA-555 Mk II and my experiences parallel yours with respect to their sonic characteristics with SDA's. I currently use a GFA-555 Mk II with a pair of CRS+'s in my office rig.
