Eh guys slight problem here.
ward91
ward91 Posts: 338
edited April 2008 in Speakers
Hello all;
I was watching ALIEN resurrection earlier on today quite loud ,and I kind of broke my subwoofer. As you can see from the pics I sent the coil so far it went out the magnetic gap and hit the magnet. Its kind of stuck. The driver is 550wrms and 1100w peak I was delivering 1000wrms. I know I should have seen it coming. Oh well looks like a chance to build a new sub .:)
ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
Post edited by ward91 on
  • McLoki
    McLoki Posts: 5,231
    edited April 2008
    Bummer - then again this is one of the few hobbies there are where, when something breaks, it is an opportunity to upgrade.
    Good luck with your new sub. Looks like you need to invest in a 15" or 18" this time.. :D
    Michael
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2008
    Awesome.
  • janmike
    janmike Posts: 6,146
    edited April 2008
    So what was "quite loud"?
    Michael ;)
    NORTH of 60°
  • george daniel
    george daniel Posts: 12,096
    edited April 2008
    Whoa Mama :eek:
  • honda cber
    honda cber Posts: 267
    edited April 2008
    is that a compressor?? is your PA rack doing some double duty? lol
    a
    gear list:
    1 down, 4 up....
  • maximillian
    maximillian Posts: 2,149
    edited April 2008
    How do you know you were delivering 1000wrms? Is there a meter somewhere?
  • ward91
    ward91 Posts: 338
    edited April 2008
    honda cber wrote: »
    a
    it is, i use my pa amp and graphic eq for my sub, the eq allows for more gain and a real thumpy bass, i should really have cut 25hz (i usually doo)as this is "subsonic" and would most likely prevent over excursion. i dont use the comp at home.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • ward91
    ward91 Posts: 338
    edited April 2008
    no your right i don’t actually know but;
    my power amp is rated at 500wrms per channel at 4ohm which is what impedance my 4ohm per coil (2 coils) sub is/was.
    The amp is also likely to have hit "clip" so it will have been over 1000w. The sub is 1100w peak so to over excurd (sp?) it I would have to be driven over 1100w?
    I know that sub bass/ bass below 40hz can oven leads to over excursion in woofers (in the pro world) but this woofer stated nothing about cutting sub bass, and it is meant to handle bass (I think) .
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • shadowofnight
    shadowofnight Posts: 2,735
    edited April 2008
    Did you pull the spider up like that or was that as found ? The bottom edge of the spider looks too clean....like the glue all pulled off in one clean motion.
    Sure you exceeded xmax....hell you even exceeded xmech....but that is the cleanest spider I have ever seen in that respect...most of the time the glue is stronger then the spider material itself and a lot of the spider is left shredded on the edge.
    At least you killed it with style :D
    The first rule of Fight Club is you don't talk about Fight Club
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited April 2008
    That's impressive, Trooper !
    I don't know how your "4 ohms per coil/2 coil" sub is wired: are those coils in Parallel or Series ?
    In Parallel, you're talking 2 ohms and you might be giving your amp a hernia.
    Sorry for your sub loss, but thanks for posting those pics.
  • honda cber
    edited April 2008
    i am only guessing, but with the power amp mentioned, he is probably running---- well, WAS running--- the sub in "stereo" (even if it is summed to mono somewhere). most amps like that can do 2 ohms per channel all night. bridged is a different story, however. for example, my mackie FR-M800 is rated at 275wpc 4 ohms and 400wpc 2 ohms. but bridged, the rating is 800w into 4 ohms, and 2 ohms is not recommended. i never bridge it, but often run 2 ohm loads for hours at a time.
    a
    gear list:
    1 down, 4 up....
  • ward91
    ward91 Posts: 338
    edited April 2008
    i found it like that, just took the woofer out and took some pics.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • ward91
    ward91 Posts: 338
    edited April 2008
    i ran my amp in "stereo" 4ohm per side on the amp.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • shadowofnight
    edited April 2008
    I just finished one of my TC Sounds subwoofers this week , and I am using one of my bridged Rockford Fosgate RF2000 amps with it. Bridged into 8 ohms its 600 watts per channel...bridged into 4 ohms its 1,200 watts per channel .....the sub is a 4 ohm load ( 4 ohms is the lowest recommended ohm load to run bridged...thats basically a 2 ohm per channel load on the amp while bridged )
    I am using every bit of its BL linear one way 30mm xmax ....staying away from the one way xmech of 46mm :D
  • shadowofnight
    edited April 2008
    ward91 wrote: »
    Did you at least say in a proper scooby doo tone " Rot Ro Raggy " :D
  • ward91
    ward91 Posts: 338
    edited April 2008
    I’m not a pyromaniac. i just like fire.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • mrbigbluelight
    edited April 2008
    By gawd, there isn't anyone who can say that you don't have style !
    ... maybe not the best luck, but ..... that was good !
  • shadowofnight
    edited April 2008
    ward91 wrote: »
    Damn.....Krakatoa !!!!!
