Using a different Microphone for MCACC
Tomasito
I am unsure if this is the correct forum to post this question.
Has anybody tried using a high end microphone to calibrate the Pioneer MCACC ?
Post edited by Tomasito on
I havent, but I dont think a high end mic is needed. the mic should only be measuring sound level, not the sound to a detailed degree, just the spl right? unless I am missing somethingLiving Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
I plan to use an omnidirectional microphone.
I thought the MCACC microphone was already omni-directional? At either case I wouldn't brother changing out mic., doing so may mess with the operation of the EQ in the setup of.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
yes, it has a factory omni-directional mic with it.
I just want to fun experimenting and observing the results.
I do expect it will have a different eq result -
Actually you can. the Mcacc is calibrated to the given mic. I suggest writing down you spec's or keep around the factory mic. I don't see any reason to use another Mic.
None.Dan
Mantis, you are right this what they were telling me. I just intend to experiment.
I found an audio technica onidirectional condenser boundary mic.
I just place an on line purchase for this mic, I should have it next week.
I will run my experiment the weekend I receive the mic. -
Why? sheer bordom? Well if anything have fun with it. I find it to be a waste of time.
DanDan
Tomasito, it would be interesting to hear what your results were. Both good and bad results are interesting.
I'm not expecting the sound to be better than using the calibrated microphone, but if the difference is small I might as well save myself the $38 + shipping + customs charges for the original microphone. :-)
