Cleaning LSIs
Just wondering what everybody used to clean the LSIs. I wanted t maintain a scratch free appearance on my beautiful speakers.
LSI 15
LSI C
LSI FX
80 fx ls for atmos
Velodyne SPL-10
Marantz 7012
Panasonic 9000
JVC 420
LSI C
LSI FX
80 fx ls for atmos
Velodyne SPL-10
Marantz 7012
Panasonic 9000
JVC 420
Post edited by bondslex on
Steel wool and a pressure cleaner.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Are we talking about the new Weber LSi cleaning method?I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
how about windex and a very soft cloth. . .Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
What about dry cleaning? I heard this keeps the drivers and electrical components from getting wet and going bad.
This is also a good idea I suppose... I'll second it.how about windex and a very soft cloth. . . -
Just a plain old Micro-fiber cloth is what I use to clean my gear.Money Talks, Mine says Goodbye Rob!!!!
I second this.Grimster74 wrote: »Just a plain old Micro-fiber cloth is what I use to clean my gear."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Its amazing when a newbie ask a simple question the smart a@$ comments he gets.
TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
When the time comes, don't forget to give everyone another reminder of your unique cleaning method when you decide to post a for sale ad of your speakers.wingnut4772 wrote: »Steel wool and a pressure cleaner.
Pretty funny Darla. Your post was worth the chuckle. A great product that gets my Focal's looking brand new [they are black lacquer as well] is "Invisible Glass" from Stoner. Spray it onto a very soft towel or microfibre cloth and they will look as if you just took them out of the box for years to come.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
mightymouse wrote: »When the time comes, don't forget to give everyone another reminder of your unique cleaning method when you decide to post a for sale ad of your speakers.
What the hell, I'll even throw in the steel wool!:DSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Greg,
You don't need any specialized cleaners. All you need is a rag/old t-shirt, and warm water from the faucet. Dip part of the cloth into the water and rub the speaker until the finger prints are removed, and then dry. Blamo, you're done!
If there is a lot of fingerprints I usually put a few drops of dish detergent in some warm water, seems to get rid of prints quick. -
I asked this question a while back, check out the archived thread ....
http://www.polkaudio.com/forums/showthread.php?t=58526&highlight=piano+black+clean -
I usually just cover each speaker with a towel when I am not using them. Keeps the dust and fingerprints off.
What about the grill?
fatchowmein wrote: »What about the grill?
Toothpaste.:DSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
I use a large camera lens cloth. It won't scratch a lens so I am sure it is good enough for the speakers.Michael
NORTH of 60° -
I lightly vacuum mine.HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
Swiffer for dust and water and micro for prints and dirt.
I clean all of my equipment with a chamois and warm water, to include my DLP screen. "Cleaning agents" can sometimes damage plastic face/display plates.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Microfiber cloth and light water. No dusting sprays needed. You can if something happens like kids or dogs but thats about it.
DanDan
I would say use wood cleaner (sparingly) only for the side panels. As others have mentioned, microfiber cloth or other soft cloth on all surfaces. Also, wipe dust off periodically; don't let it cake on. If you will be on vacation for a while, cover the speakers to avoid dust accumulation. Actually, just place the speakers in a class 1000 clean room and be done with it.
swiffer duster when there's just dust.
for fingerprints and general schmutz, microfiber is fine, if not a litle overkill. the old t shirt is fine too. I used pledge and it works fine, but I dont wipe it too often, relying on the swiffer to do most of the work
if the LSi's piss you off, THEN you go with the steel woolLiving Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
maximillian wrote: »I would say use wood cleaner (sparingly) only for the side panels.
pledge works ok for the side panels too, again, I dont do it often
wipe it off real good thoughLiving Room 2 Channel -
Lint roller on the grills. Maybe a little warm water on a towel if there is something that needs to be rubbed out.
Seems something always needs to be rubbed out.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Laquer thinner and/or acetone work well.
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma -
microfiber cloth,
If really dirty:
run the cloth under the faucet
wring it out
wipe off speaker
wipe off speaker again with a microfiber cloth that is still dry
done. (have not had to do more that yet....)Mains.............Polk LSi15 (Cherry)
Spit & microfiber cloth.The Escape Pod Equipment
Samsung HL-S5679W
Sony STR-DA5200ES
Outlaw 7125
Sony 60GB PS3, Blu-ray Disc
TiVo Series 3 HD
Universal Remote Control MX-900
Polk Audio LSi9 ebony, fronts
Polk Audio LSiC, center
Polk Audio LC65i in wall, surrounds
SVS PB12-Plus Piano Black
Outlaw PCA interconnects
BetterCables for HDMI & SUB
Master Bedroom
Sony KDL-46XBR4
Sony 40GB PS3, 2nd Blu-Ray Disc
Polk Audio i-Sonic
