What kinda gas do you buy for your car/truck?
Jstas
I was just reading an article about this. It's said to be a marketing thing and there is no difference that anyone can discernibly tell between a tank of say Chevron and a tank of Costco.
Honestly, there really is little difference between brands because it all comes out of the same refineries and has to meet federal standards. The way they do it is if company A puts 200,000 barrels into the system and company B puts 300,000 barrels in, company A gets the equivalent product that 200,000 barrels would produce and company B gets 300,000 barrels. Beyond that, whatever additives the different companies add is what makes any difference.
So do you see a difference depending on where you fill up?
The only difference I've ever seen is between a tank of premium Sunoco Ultra and a tank everywhere else. Well, not so much anymore because Ultra doesn't come in 94 octane anymore and that is where the difference was. Got better mileage, better throttle response and smoother running with a tank full of Ultra 94.
Expert Moron Extraordinaire
Post edited by Jstas on
I stay away from Racetrack(moisture in the gas problems).
Other than that, low price regular."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Chevron premium 'cause it's the most convenient gas station and 'cause I gotta use premium with my car (at least that's what the owner's manual says).HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Cheapo regular. Thankfully don't need to use anything other than 87, and have never noticed a difference between stations (and I always am checking my mileage so I'd notice).If you will it, dude, it is no dream.
Most gas problems will be from station issues, not refinery issues (dirty tanks, water in tanks, etc).
You're partially correct. All gas is basically the same until it reaches the distributor (Chevron, Shell, Exxon, etc). The major companies add their proprietary additives at the loading rack when it is pumped into the tanker for delivery to the station. It's the additives that make one brand better than another. Chevron's Techron additive is the best according to the studies I've read. Most distributors group together in one central location and actually have piping between their plants for the purpose of swapping gas between themselves. Water in the fuel rarely happens at the distributor, but comes from poorly maintained tanks at the gas station. UGT's should be checked monthly for water build-up and the water pumped out if present.
Chevron Premium. My car requires premium (turbo). I've read that Chevron's Techron is the best and it also happens to be the most convenient gas station based on where I live/work.
Um, not sure who you were referring to but if it was me, maybe you missed this part of my post: "...Beyond that, whatever additives the different companies add is what makes any difference."Expert Moron Extraordinaire
Racetrack has been known for the water in the gas. I had problems with several stations. Others have told me the same. Maybe a distribution center issue? I don't believe they are anything but a local (Texas?) brand."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Hi-Test for the Jeep, cheap **** for everything else.
I stop at the Giant food store gas station, because they're close, resonably priced, and good quality. Plus, I get money off gas after buying x amount of groceries.
One of the worst (and, surprise, cheapest) places around is a little noname station up the street. Run by your stereotypical "Qwikee Mart" folks... Always the lowest price, but I've had so many people come into Autozone complaining that their car doesn't run right. I ask them where they just filled up... "Oh, that cheap place across from K-Mart". My guess is, water in the tanks.Ludicrous gibs! -
I always use Mobil. 93 for one, 89 for the other (per manufacturer specs). I like Mobil because of the convenience of the speedpass and I like the stations. A few cents a gallon difference means nothing to me, so I rarely go shopping for the lowest price.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Unleaded - 89 from wherever.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Diamond Shamrock regular, because it's close to home, and that's what grade my F-150 calls for.
FWIW, If I weren't a cheap bastid, I'd put Chevron in, because it seems my truck runs better on it.My equipment sig felt inadequate and deleted itself. -
Chevy Duramax drinks diesel. But, delivers 24 mpg.
Usually Shell out of convenience and sometimes Chevron. My car takes premium which is 92 octane around here. I can't tell any difference mileage or performance-wise between the two brands.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Regular BP seems to produce better mileage in my Titan than other brands.McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
I buy Shell V-Power simply because it's higher octane than just about all other gas stations around here and it costs the same per gallon as the lower octane counterpart at another station
Most stations around here including the big ones, BP and Mobil and Marathon sell these octane ratings
87-regular
89-plus
91-premium
Shell sells:
89-regular
91-plus
93-premium
for the same price as the other stations sell the lower octane.
My car has a few mods including a chip and it needs 93 octane to run it's best.
The only other difference I've ever read about is the detergent formulations are different from brand to brand. They all meet federal regulations. Also some companies use fuel with a higher percentage of ethanol. I prefer a lower percentage of ethanol or no ethanol at all. I don't think Shell uses ethanol in the V-Power fuel."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
91 Chevron. I've used that gas all my driving life and never once had a single issue because of it.If...
Ron loves a film = don't even rent. -
Whatever is the cheapest. I would put water in my tank if it would work.
Regular. Closest station when the reserve light goes on.
I used to pay attention to gas that gave best performance, but that was when I was in my 20's._________________________________________________
I always liked the way my cars/trucks ran on Hess/ Mobil / Texaco / Sunoco.
I use 89 and 93 in my trucks.Dan
My car takes premium gas, and I usually buy it at Shell (in Canada). Shell's Gold gas has 0 ethanol in it.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Pioneer SC-37
RTiA9-fronts
CSiA6-center
RT55i-surrounds
SVS PB13 Ultra & PSW650
Monster Power 3250 amp
Monster Power 2250 amp
Monster Power HDP-2500 surge pro.
Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust -
Chips are bogus, your cars comp. re-learns the factory specs. save your money
H9Pioneer SC-37
RTiA9-fronts
CSiA6-center
RT55i-surrounds
bassaholic wrote: »Chips are bogus, your cars comp. re-learns the factory specs. save your money
You obviously know nothing. :rolleyes:"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
I buy from Petro- Canada as I like to check my tire pressure and they have free air, plus it's about 2mins from my house. BTW I usually buy 89 once in a while I'll fill it with premium. But 99% it's 89.
Sams Club or Costco, which ever we're closer to when it's time. Never had knocking or other ill effects from these.Husband, Father, Son, Brother, Friend.
Lukoil had a big problem up here by me. 7 tanker loads of water logged gas from a dirty tank got distributed. Gas tanks filled, cars stopped running about 5 miles later. thousands in damage per car. bad Mojo. won't be going to a Lukoil any time soon.
your right that most gas the same, but oddly enough, my truck (91 GMC) seems to run a little better on the gas from the gulf station by my house.
I loaded up with a gas station in Newark recently and the truck ran just a little rough, so sometimes there might be some differences.
for the Stang, it's 89 octane from this gulf station, since thats what was in the tank when JDM tuned it ....why eff up a good thing unless I really have too?Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
bobman1235 wrote: »Cheapo regular. Thankfully don't need to use anything other than 87, and have never noticed a difference between stations (and I always am checking my mileage so I'd notice).
+1.
