What kinda gas do you buy for your car/truck?
Jstas
Jstas Posts: 14,985
edited April 2008 in The Clubhouse
I was just reading an article about this. It's said to be a marketing thing and there is no difference that anyone can discernibly tell between a tank of say Chevron and a tank of Costco.
Honestly, there really is little difference between brands because it all comes out of the same refineries and has to meet federal standards. The way they do it is if company A puts 200,000 barrels into the system and company B puts 300,000 barrels in, company A gets the equivalent product that 200,000 barrels would produce and company B gets 300,000 barrels. Beyond that, whatever additives the different companies add is what makes any difference.
So do you see a difference depending on where you fill up?
The only difference I've ever seen is between a tank of premium Sunoco Ultra and a tank everywhere else. Well, not so much anymore because Ultra doesn't come in 94 octane anymore and that is where the difference was. Got better mileage, better throttle response and smoother running with a tank full of Ultra 94.
Expert Moron Extraordinaire
Post edited by Jstas on
«13
  • sucks2beme
    sucks2beme Posts: 5,682
    edited April 2008
    Jstas wrote: »
    I stay away from Racetrack(moisture in the gas problems).
    Other than that, low price regular.
  • Early B.
    Early B. Posts: 7,900
    edited April 2008
    Chevron premium 'cause it's the most convenient gas station and 'cause I gotta use premium with my car (at least that's what the owner's manual says).
    "God grooves with tubes."
  • bobman1235
    bobman1235 Posts: 10,822
    edited April 2008
    Cheapo regular. Thankfully don't need to use anything other than 87, and have never noticed a difference between stations (and I always am checking my mileage so I'd notice).
  • nms
    nms Posts: 671
    edited April 2008
    Most gas problems will be from station issues, not refinery issues (dirty tanks, water in tanks, etc).
    My system
    "The world is an ever evolving clusterf*ck." --treitz3
  • skipf
    skipf Posts: 694
    edited April 2008
    You're partially correct. All gas is basically the same until it reaches the distributor (Chevron, Shell, Exxon, etc). The major companies add their proprietary additives at the loading rack when it is pumped into the tanker for delivery to the station. It's the additives that make one brand better than another. Chevron's Techron additive is the best according to the studies I've read. Most distributors group together in one central location and actually have piping between their plants for the purpose of swapping gas between themselves. Water in the fuel rarely happens at the distributor, but comes from poorly maintained tanks at the gas station. UGT's should be checked monthly for water build-up and the water pumped out if present.
  • PhantomOG
    PhantomOG Posts: 2,409
    edited April 2008
    Chevron Premium. My car requires premium (turbo). I've read that Chevron's Techron is the best and it also happens to be the most convenient gas station based on where I live/work.
  • Jstas
    Jstas Posts: 14,985
    edited April 2008
    skipf wrote: »
    Um, not sure who you were referring to but if it was me, maybe you missed this part of my post: "...Beyond that, whatever additives the different companies add is what makes any difference."
  • sucks2beme
    edited April 2008
    nms wrote: »
    Racetrack has been known for the water in the gas. I had problems with several stations. Others have told me the same. Maybe a distribution center issue? I don't believe they are anything but a local (Texas?) brand.
  • Frank Z
    Frank Z Posts: 5,860
    edited April 2008
    Hi-Test for the Jeep, cheap **** for everything else.
  • nadams
    nadams Posts: 5,877
    edited April 2008
    I stop at the Giant food store gas station, because they're close, resonably priced, and good quality. Plus, I get money off gas after buying x amount of groceries.
    One of the worst (and, surprise, cheapest) places around is a little noname station up the street. Run by your stereotypical "Qwikee Mart" folks... Always the lowest price, but I've had so many people come into Autozone complaining that their car doesn't run right. I ask them where they just filled up... "Oh, that cheap place across from K-Mart". My guess is, water in the tanks.
    Ludicrous gibs!
  • tcrossma
    tcrossma Posts: 1,301
    edited April 2008
    I always use Mobil. 93 for one, 89 for the other (per manufacturer specs). I like Mobil because of the convenience of the speedpass and I like the stations. A few cents a gallon difference means nothing to me, so I rarely go shopping for the lowest price.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2008
    Unleaded - 89 from wherever.
  • Rivrrat
    Rivrrat Posts: 2,101
    edited April 2008
    Diamond Shamrock regular, because it's close to home, and that's what grade my F-150 calls for.
    FWIW, If I weren't a cheap bastid, I'd put Chevron in, because it seems my truck runs better on it.
    My equipment sig felt inadequate and deleted itself.
  • rskarvan
    rskarvan Posts: 2,374
    edited April 2008
    Chevy Duramax drinks diesel. But, delivers 24 mpg.
  • dragon1952
    dragon1952 Posts: 4,907
    edited April 2008
    Usually Shell out of convenience and sometimes Chevron. My car takes premium which is 92 octane around here. I can't tell any difference mileage or performance-wise between the two brands.
  • StevieB
    StevieB Posts: 257
    edited April 2008
    Regular BP seems to produce better mileage in my Titan than other brands.
    McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
    heiney9 Posts: 25,430
    edited April 2008
    I buy Shell V-Power simply because it's higher octane than just about all other gas stations around here and it costs the same per gallon as the lower octane counterpart at another station
    Most stations around here including the big ones, BP and Mobil and Marathon sell these octane ratings
    87-regular
    89-plus
    91-premium
    Shell sells:
    89-regular
    91-plus
    93-premium
    for the same price as the other stations sell the lower octane.
    My car has a few mods including a chip and it needs 93 octane to run it's best.
    edited April 2008
    The only other difference I've ever read about is the detergent formulations are different from brand to brand. They all meet federal regulations. Also some companies use fuel with a higher percentage of ethanol. I prefer a lower percentage of ethanol or no ethanol at all. I don't think Shell uses ethanol in the V-Power fuel.
  • Ron-P
    Ron-P Posts: 8,520
    edited April 2008
    91 Chevron. I've used that gas all my driving life and never once had a single issue because of it.
    If...
    Ron loves a film = don't even rent.
  • Libertyc
    Libertyc Posts: 915
    edited April 2008
    Whatever is the cheapest. I would put water in my tank if it would work.
  • Ricardo
    Ricardo Posts: 10,636
    edited April 2008
    Regular. Closest station when the reserve light goes on.
    I used to pay attention to gas that gave best performance, but that was when I was in my 20's.
    SOPA
  • mantis
    mantis Posts: 17,351
    edited April 2008
    I always liked the way my cars/trucks ran on Hess/ Mobil / Texaco / Sunoco.
    I use 89 and 93 in my trucks.
    Dan
  • ViperZ
    ViperZ Posts: 2,046
    edited April 2008
    My car takes premium gas, and I usually buy it at Shell (in Canada). Shell's Gold gas has 0 ethanol in it.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • bassaholic
    bassaholic Posts: 315
    edited April 2008
    dorokusai wrote: »
    +++++1
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
    SVS PB13 Ultra & PSW650
    Monster Power 3250 amp
    Monster Power 2250 amp
    Monster Power HDP-2500 surge pro.
    Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust
  • bassaholic
    edited April 2008
    heiney9 wrote: »
    Chips are bogus, your cars comp. re-learns the factory specs. save your money
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
    edited April 2008
    bassaholic wrote: »
    You obviously know nothing. :rolleyes:
  • Willow
    Willow Posts: 11,231
    edited April 2008
    I buy from Petro- Canada as I like to check my tire pressure and they have free air, plus it's about 2mins from my house. BTW I usually buy 89 once in a while I'll fill it with premium. But 99% it's 89.
  • apc
    apc Posts: 779
    edited April 2008
    Sams Club or Costco, which ever we're closer to when it's time. Never had knocking or other ill effects from these.
    Husband, Father, Son, Brother, Friend.
  • ohskigod
    ohskigod Posts: 6,505
    edited April 2008
    Lukoil had a big problem up here by me. 7 tanker loads of water logged gas from a dirty tank got distributed. Gas tanks filled, cars stopped running about 5 miles later. thousands in damage per car. bad Mojo. won't be going to a Lukoil any time soon.
    your right that most gas the same, but oddly enough, my truck (91 GMC) seems to run a little better on the gas from the gulf station by my house.
    I loaded up with a gas station in Newark recently and the truck ran just a little rough, so sometimes there might be some differences.
    for the Stang, it's 89 octane from this gulf station, since thats what was in the tank when JDM tuned it ....why eff up a good thing unless I really have too?
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Joe08867
    Joe08867 Posts: 3,919
    edited April 2008
    bobman1235 wrote: »
    +1. :)
