Huzzing in the channel
NeilGabriel
I hooked up a new to me B&K avr 202 tonight. Everything worked fine until I turned it off (sleep mode). I then noticed a fairly audible humming/buzzing in front left channel that did not stop. When I powered it totally down, it stopped. When powered up, it stopped. I also noticed that all speaker outputs seem to have a little current on the sleep mode by tapping the positive speaker wire to the terminal and getting a little sound out of each speaker. However, only the front left has the humming. I moved some cords around, switched power outlets. Any useful thoughts will be greatly appreciated.
Mike
Mike
Post edited by NeilGabriel on
The only thing might be to flip the power cord but you said its new so i dont think you could do that. Ummmm... does it have a ground screw in the back so you can ground all of your equipment together if it does that would be something to try. i hope i have help a little not having any exp. with B&K products.If life had more tubes it would be a lot smoother.
I think you'd better plan on calling B&K on Monday.Political Correctness'.........defined
President of Club Polk -
But you guys are my tech support! I've tried all the normal stuff. Found a posting on another forum about somebody having similar problem and B&K fixed it no charge...said it was a leaking capacitor. -
But you said new. LOL We could ask you to open it up and look inside but I think that messes with the warranty. LOL
engtazengtaz
new to me....it's about 4+ yrs old....I just got it off v-gon...and I trust the seller that he did not have the issue.....in fact, when I first hooked it up and turned the main power on, then put it in sleep, I don't recall the hum. I think it started after I had played a movie through and put it back in sleep mode. Now, it hums in the front left whenever it is in sleep.
what was that... hussies in one channel?
Seriously... a good descriptor, that was. -
Sounds like it could be a ground loop or bad cable.Did you try switching left and right channel I/C's ?HT SYSTEM-
lsi 9's -
For what it's worth, there is also a good sized popping in the same channel when the unit turns off and on. I connected the speaker to all channels, and only the front left is producing this problem. Sounds like I will need to send it in. Any possibility that a wire on the output got loose in shipment?
