Will the owner of this pic please stand up (SDA XO)
ben62670
ben62670 Posts: 15,969
edited April 2008 in Vintage Speakers
Picture333.jpg?t=1208412726
Nice work from a newbie:)
He can take over from here...
Edit
posted pic for domesda2b
Ben
Post edited by ben62670 on
    F1nut Posts: 51,943
    edited April 2008
    Very nice!
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Thanks Club Polk for helping me complete my project!
  • ben62670
    edited April 2008
    I love those inductors. I have used a few, and the added bass is very nice.
    Enjoy!
    Ben
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Really enjoying.. I ended up using high density 1/8" thick x 1/4" high density foam tape weatherstrip to reseal all drivers. Two strips around each speaker. Orgasmic!
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Can really tell the difference in low resistance on that iron core inductor.
  • george daniel
    george daniel Posts: 12,096
    edited April 2008
    Very nice indeed. Looks like you put a lot of thought and time into those.
  • Boywonder
    Boywonder Posts: 225
    edited April 2008
    Not to thread hijack, but what are the saw "score-cuts" in the panels for? I'm assuming that they are possibly for changing/reducing panel resonance. The pic above clearly shows the saw "score-cuts" in the panels. My SDA's have the cuts, by my monitors don't.
  • strider
    strider Posts: 2,568
    edited April 2008
    There have really been a bunch of nice looking, pimped out, 2B's poppoing up lately.
    Nice work!
    Wristwatch--->Crisco
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Information on how my project got started, help and directions.
    Thank you,
    http://www.polkaudio.com/forums/showthread.php?t=65894
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Boywonder wrote: »
    Probably to save on wood. No really, I have no idea, maybe they got a good deal on the material hehe.. maybe someone else will chime in on this. All I know is I didn't want and mounting bracket screws going into that slot! Peace...
  • NotaSuv
    NotaSuv Posts: 3,871
    edited April 2008
    very very nice work my friend
  • schwarcw
    schwarcw Posts: 7,358
    edited April 2008
    Very nice work domesda2b! I like how you put everything on a new mount. New inductors is interesting. I never had the initiative to try it. Maybe too much fear of the unknown. It looks like you re-sealed the perimeter with glue. Is that Liquid Nails or what?
    Welcome to club Polk!:)
    Carl
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    schwarcw wrote: »
    Apparently it's a factories attempt at a hot melt glue gasket.. Ok, my right sda speakers passive sub is weaker than the left. I replaced made up new tweeter seal, sealed binding posts and connect cable socket. Still not as strong as right! makes me wonder if a factory hot melt glue seam is bad? Interesting question. No I did not put that glue around the inside! I'm going to take everything out of the box wires and things and then dump a gallon of something or other inside and shake it around. Hmm does one of those giant size warehouse clubs sell giant packs of hot melt glue? But where would I find a gun big enough I'd have to cook it outside in a pot or on the stove and pour it in...:D
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    I mean left hehe
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Ok I think I fingered out the mystery of the weak right channel passive sub. I had the green and blue wires switched on the right 6511 driver. Ooops I did a.. Happens to the best of us. Sounds much better now:)
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Dang now I gotta check them all! Oops I better not multi-post. hey this is good information. Another problem figured out! Thanks
  • NotaSuv
    edited April 2008
    its that ongoing commentary that makes the post :)
  • honda cber
    honda cber Posts: 267
    edited April 2008
    domesda2b wrote: »
    Really enjoying....... Orgasmic!
    wait.............
    you are using SL2000WC?????
    :rolleyes:
    a
    gear list:
    1 down, 4 up....
  • geoff727
    geoff727 Posts: 546
    edited April 2008
    A very clean, professional looking crossover. Very nice to look at!! Are those Dayton caps?
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS-II (modded)
    Infinity RS-IIIa (modded)
    Infinity RS 2.5 x 2
    Magnepan 1.6QR (modded)
    System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Using silk dome rdo 194 tweeters. yes dayton audio caps. Yes, commentary good:)
