B&K 125.2 S2.... Opinions PLZ
Jer.War
I am looking at this amplifier to power my LSI15's (hoping it will open up the bottom end a bit and give more overall control (running off a Yamaha RXV1800 now). I was looking at the specs and see that the damping factor is 180. Is that too low or am I misinterpreting the specs in some way. If anybody owns this amp and can give me a review on how well it stacks up w/ adcoms or rotels that would be great. I enjoy a warmer sound with full low end.
Thanks oh wise Audio Guruus:)
[The Ever-Evolving System
LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
Post edited by Jer.War on
"A high damping factor indicates that an amplifier will have greater control over the movement of the speaker cone, particularly in the bass region near the resonant frequency of the driver's mechanical resonance."
This is why I like Adcom's over some other brands. With lower dampening factor some speakers like the older Polk's will pop, because the amp doesn't have the ability to control the cone movement.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
It's a solid amplifier and damping factor is not something to worry your head about.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Seconded. DF >100 = teh win.
I'm lovin' my 200.2 S2. -
I have a 200.5 and think it matches wonderfully with the LSi15's. So while I don't have experience with that particular amp I'm guessing you'll be very happy with it.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
I know that amp very well. After dampening factor gets over 80, you can assure it wil handle most if not all speakers properly. It goes to 185 watts in a 4 ohm load and does it very very well. It will make your Lsi's sing. I also feel you should consider a B&K preamp. This will really make a bigger difference then just the amp alone. It will provide the correct amount of current required by your speakers but sound quality is going to be still of the sound of Yamaha.
I really like B&K gear. It's so solid.Dan
I owned this amp for a while
Pretty solid monster. Couldn't get it to clip.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
That says alot about your listening habits on gear.....but who hasn't tried to push the envelope now and then huh?
CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I power my LSi9's in my HT with the B&K 125.2. As noted, solidly built high quality amp with great sound quality.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
This would have been a nice amp. for the money
http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1212441203 -
Thanks for the quick replies, and good advice. Now I just need to scrounge up some funds
