No more preamp or sub for me!
pearsall001
I suprised even myself with this one. After my recent purchase of a Velodyne SPL-1200R sub I had a lot of fun with different hook-up scenerios. The one I liked the best was with the Krell preamp thru the velo hi-pass hook-up back to the Krell amp. This sounded wonderful. Then on a wim I decided to try something different.
I took the Krell preamp out completely & using the NAD T773 receiver as the preamp & for bass management I was taken back by the performance (NAD isn't kidding with their "Music First" slogan). To these old worn out ears there was absolutely no difference in sound between the two set-ups. I listened for about a week then went back to the Krell pre. Yep, my ears were right, so out came the Krell pre.
Next up was the SVS cylinder sub. The velo made mince meat out of it in HT & especially 2 channel listening (for music it simply was no contest). So now I have the NAD T773 as my control center & with it's great bass management my system now performs flawlessly. Bottom line...less gear, less IC & PC's all equals exceptional sound.
And I must add that with the addition of the Velo, my 2 channel listening has been raised thru the roof. What a sub like that brings to the table has to be heard to be believed!! You guys that are balls sure that you don't need a sub...think again. Ther's a whole lot that your missing. I don't care what bottom end you think your speakers are bringing to the table, it's just not there.
And for all you guys who thought I'd be selling the Velo...:p
The Krell pre & SVS have been sold!
Post edited by pearsall001 on
Hmmm...the Krell pre & SVS doesn't surprise me.
And I can certainly understand your use of the NAD receiver as a pre. I'm currently using the Emotiva LMC-1 as a pre and it sounds very good. Never thought I'd do it, either. However, that last little 1-2% of tone and midrange magic are missing, so I gotta get it back. Then I'm done. Eventually, you'll come to the same conclusion (except for the "I'm done" part).HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Which SVS did you have?2 Channel rig:
LSi9"s (modified xover's) & HSU Sub
Harman Kardon HK 990 Amp
Onkyo C-S5VL SACD
Music Hall MMF 5.1
Furman Elite 15
HT rig:
HK AVR-745 & Polk Monitor Series -
AudioFilet wrote: »Which SVS did you have?
SVS...25-31plus cylinder. -
pearsall001 wrote: »Next up was the SVS cylinder sub. The velo made mince meat out of it in HT & especially 2 channel listening (for music it simply was no contest).pearsall001 wrote: »SVS...25-31plus cylinder.
Damn - wish I hadnt read that. Now I really want to upgrade.....
:rolleyes:
Epik - here I come....Mains.............Polk LSi15 (Cherry)
.does the svs just not go as low, or just dont have the output?
Thanks -
I hear ya EB. But I think I'm finally winning the battle of "Audio Nutism". If what I just did cost me 1-2% of sonic bliss...then I am quite happy & estatic!!. Truth be told, I couldn't hear the difference or really care if I did. This constant tail chasing (relates to $$$$ & a whole lot of nonsense) for that last, minute, unaudible & unattainable bit of detail. Because once you've thought that you've found it...the quest for even better continues. One has got to learn when to apply the brakes & return to audio sanity.
Right now, with the addition of the Velo SPL-1200R my system is literally rocking in both HT & 2 channel. I've cut my tail off & am kicking back & enjoying my system. I am at peace with the audio gods now!!
:D -
greene1968 wrote: ».does the svs just not go as low, or just dont have the output?
Not wanting to turn this into svs/velo discussion thread here's a quick answer.
The svs is a superb sub, so is the velo. I would be just as happy with either in HT but not for music. Just my $.02
Now if you move up to the svs ultra series...that's a whole different ball game. Howerer the ultra series are just to darn big for my space limitations. The velo at 14x14x15 is just perfect space & performance wise. -
Nice to see SOMEONE stop drinking the "Upgrade Koolaid"!
Congrats.I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
I can swap out good solid state AVR/preamps all day long and not miss them. Its my tube preamps that I have a hard time letting go of.....and my mains have been big enough for years to sound best without a sub for music.
I do use the subs for HT but with 8 ft. front projection for going on 5 years now, you stop effing your mind up with how good things look and sound and just enjoy the film.
What I do like about your choice is just keepin' it simple........HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Congrats Phil! Enjoy your setup & having more money in your pocket & time on your hands to just kick back & listen to what you've put together!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
pearsall001 wrote: »I hear ya EB. But I think I'm finally winning the battle of "Audio Nutism". If what I just did cost me 1-2% of sonic bliss...then I am quite happy & estatic!!. Truth be told, I couldn't hear the difference or really care if I did. This constant tail chasing (relates to $$$$ & a whole lot of nonsense) for that last, minute, unaudible & unattainable bit of detail. Because once you've thought that you've found it...the quest for even better continues. One has got to learn when to apply the brakes & return to audio sanity.
:D
Very nice, then. I'm glad you found what you're looking for.
Here's my situation -- I know my system can sound better because I've heard it. Same CDP, same speakers, but now I have a different amp and pre. When my system sounded its best, it lacked dynamics, but I've fixed that issue with the subs and removal of the passive pre. Now I want to hear that nut-tingling female vocal midrange again. The Promitheus TVC and Marsh amp were the keys to this magic. Gonna get the magic back soon, but in a different (and less expensive) form. When I do, I'll should have the sound I want, then I can jump off the upgrade merry-go-round. Of course, Pear, I think you're still on the ride talkin' 'bout, "Wheeeeeeh!";)HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Does the NAD have balanced XLR's?
No it doesn't. That wasn't as much of a stumbling block as I first thought. Since the Velo doesn't have XLR connections, that pretty much finalized that decision. However down the road when it comes time to find a replacement for the T773, I'll make sure it has XLR's. -
I have a sub that comes over sometimes when the mood hits me, we go into the Shed and the sub is always scared of the low sounds coming from the two speakers in the room.
RT1 -
Good deal!
You know, as far as HT goes...I've done receivers and separates and gone back and forth a couple of times. I'm going back to a receiver. Yes, separates sound better for music but the simplicity and so forth just make a receiver a better option for HT for me.
Congrats.
He'll relapse . . . everyone does. -
SolidSqual wrote: »He'll relapse . . . everyone does.
He probably relapsed already.;)HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Seriously, I remember when I bought my Odyssey gear and was running a pair of AZ Adagios. I thought I would have that system for years! It lasted a month. My present system is entirely new and is still here after one month. So I've hit a personal record. That being said, I did buy a new sub for HT apps.
You're screwed pearsall, all the extra room means you are gonna start itching to fill it with new gear. -
I'm quite happy with +-$500 components. In other words, I have no desire to own a krell or a svs. Not that they aren't worth the money but they aren't for me.
candyliquor35m wrote: »I'm quite happy with +-$500 components. In other words, I have no desire to own a krell or a svs. Not that they aren't worth the money but they aren't for me.
Well, you could buy a Krell amp and just make it for you; you know, open it up and take out a few resistors, add a few caps. Make it orgarsmic like your SL2000's._________________________________________________
Well, .
Since you volunteered go ahead and do that for me and send it to me and I'll demo it so I can decide if it's worth $500
I don't recall volunteering for anything. It seems you're now having visions? Hallucinating maybe?_________________________________________________
candyliquor35m wrote: »No comment. I've already made my constructive comments to this thread.
Really? In this thread? Would you mind pointing them out? I just can't see them._________________________________________________
Really
No comment. You seem to have something other than the topic of this thread on your agenda. -
Glad to hear the set up is working well for you. I agree, NAD makes some really good stuff. I have a few pieces that I don't plan to sell. Good to hear you got the sub working out in the system. I'm still having some problems getting my PSW650 to blend in with my mains.
Rock on! -
candyliquor35m wrote: »No comment. You seem to have something other than the topic of this thread on your agenda.
No comment? Well, you did make the comment on my agenda, didn't you.
I have no agenda really. Just reading your posts and replying, in what I think is not an offensive way. It's funny though...why do you always cut the quotes and just leave the first words? I've noticed you always do that.
I also noticed some threads you started were deleted; do you know why?_________________________________________________
Phil, sorry for the derail....I'll stay out of it. Just couldn't help it.
Congrats in your new findings
No
No comment
I don't understand the point of your (Ricardo) conversation nor does it involve this thread and doesn't appear to be constructive so I choose not to participate in your (Ricardo) conversation. -
Good deal!
BDT
That was my first concern...that separates would sound better for music. But my concerns were put quickly to rest. The NAD T773 receiver does a fabulous job as a preamp fpr two channel listening. I really don't miss the CJ or the Krell pre's at all. Sometimes I wonder how much we actually read into all this audio stuff & just don't trust our ears. There's a lot of sliced "bologna" that we've all eaten!!!
