Capacitor break-in
24
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Your 20 year annoyance is just about over.
    You mean somewhere someplace there's hope and a positive note! That made me feel real good. We'll see... Some people may like SL2000 tweeters using tube but I'm using solid state, so. I don't need a chart to tell me what sounds good either. The SL2000 tweeters are ok for low listening levels and classical strings but turn it up and headache for me. It does something to female voices. Someone else on this forum mentioned a spitting effect. If you listen real good maybe not at first but you will notice it if you have good ears or play music. Maybe I just don't know what I'm talking about but I know anytime someone else listened to it they said the same thing. TINNY AND HARSH. Is it the tweeters, I don't know. I'll buy anything new if I think it's better. So silk domes have holes in them?(laugh)
    F1nut Posts: 51,722
    edited April 2008
    No, the new silk domes do not have holes in them.
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Doesn't silk naturally have pores in the material or is it doped? Thanks
  • spkrdtr
    spkrdtr Posts: 11
    edited April 2008
    ben62670 wrote: »
    Was I too harsh?
    Seriously spkrdtr F1nut told me when I first got serious about this hobby that "A mind is like a paraschute... unless it is open..."
    Yup. Hey, what do I know, I'm just a hokey-Polkie. Guru's and experts always know best. Sorry to have bored you guys with a different point of view.......
  • ShinAce
    ShinAce Posts: 1,194
    edited April 2008
    domesda2b wrote: »
    Both!
    F1nut Posts: 51,722
    edited April 2008
    The Polk tweeters are rubberized silk domes.
  • zingo
    zingo Posts: 11,258
    edited April 2008
    That's weird, the last pair of RDOs I got in appear to be pure gold; although the box does say "RDO-198G"...
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Interesting
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Does that mean I can turn them up louder and they won't vibrate?
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Guess I'm trying to understand how the coil interacts with the dome. We'll see. When I took the dome seal loose on the stock plastic dome it didn't seem to effect it much so isn't that just a dust cover? later I sealed it back down even knowing the new rdo's were on the way. Hard to say shrug. Pretty much burned out on this issue.. Does it sound good? does it leak? Ok then, Bye
  • ben62670
    ben62670 Posts: 15,969
    edited April 2008
    spkrdtr wrote: »
    Its all about what you hear. It has nothing to do with specs. I am into audio like many others here. Everyone has different tastes. Stick around. Experiment a little. Hear it for yourself. I used to believe same valued/specked components would sound the same. I was pig headed for a long time. I thought these guru's with a bunch of post were all rich dummies/snobs chasing olives in their martini glasses while looking down on other peoples audio gear. Most of them will offer good solid advice just to be helpful. When 9 out of 10 senior members try to tell you something it is kinda like ask the audience. Usually they are right.
    BTW Welcome to Club Polk
    Ben
    Ben
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Exchange ideas on do-it-yourself projects with other experts; from furniture builders to obsessive compulsive tweakers. Thanks
    F1nut Posts: 51,722
    edited April 2008
    Having fun, Sal?
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    My crossover is out because I'm updating tweeters and safety guard polyswitch on my SDA 2B's. Looking at the PCB there's not much to it. Initially I see 3 capacitors and 1 resistor. Sticker says rev B 1987. It would be nice to solder in some new capacitors for fun. I need help or more direction. Might as well do everything at once if I can get the parts reasonable. how much could it cost?
  • ben62670
    edited April 2008
    Check partsexpress.com I have tried a few different caps, and for a cheap experiment with good results I recommend trying the Dayton caps, and using the mills resistors. Roughly $60
    Ben
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    ben62670 wrote: »
    Cool, now which capacitors. I see a light blue 20uf a sliver blue 40uf and a yellow can labeled T1 E-0012-1 12J and the grey ceramic 5 watt resistor. Am I missing something there is the safety guard i see. One other burgandy dark purple small component? I mean it ain't that big O board!
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    I want to upgrade my caps so bad sitting here looking at the board components and it looks like it could be some great satisfaction. can tell I get excited around soldering irons. LoL.. Suppose I'll need musical SOLDER NOW! Thanks Polk forum you really started something. jokes
  • nspindel
    nspindel Posts: 5,343
    edited April 2008
    domesda2b wrote: »
    All of them :)
    I just did my 2b's with Sonicaps, have a look here:
    http://www.polkaudio.com/forums/showthread.php?t=62106
  • nspindel
    edited April 2008
    Folks, I'm heading outta town for a week (assuming American Airlines doesn't hose me tomorrow morning). This thread seems to have gone a bit OT, I'd still love to hear more about my original question as to what's actually going on inside these caps during the break-in process. Hopefully when I get back there'll be some good enlightenment on this topic.
    See y'all in a week.
    Spin
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Ok thanks, greatly appreciated
  • ben62670
    edited April 2008
    http://www.polkaudio.com/forums/showthread.php?t=55888
    Have fun!
    2 each
    12uf, 20uf, and 40uf
    most omit the 750pf cap (little bypass one)
    2 2.7ohm mills resistors
    PE has mills for $3.25 each in 2.5ohms (plenty close enough)
    PE also has Dayton Audio 2.7ohms for $1.25 each if you want same valued resistors as stock.
    Me I would use the Mills. The resistors used in this crossover design are in series with the signal, and are before any other crossover component therefore have no adverse effect to the XO Point, or slope. They are just used to attenuate the signal so the tweeter is not over bearing.
    Ben
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    K, I have a basket going at partsexpress.com. Looking at Dayton DMPC-40 40uF 250V Polypropylene Capacitors. What uf value is the yellow cap, it doesn't say or can't read?
    I am going with new inductor coil as described in nspindel's thread listed above.
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    excuse me i see it now 12uf thanks
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Wow iI'm done shopping al except maybe better musical solder hehe! You guys are the greatest! Thanks so much that was painless as possible! What a great forum!
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    yeah the little purple brown one I see that
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Do you have the link to the mills and dayton 5 watt 2.7 ohm resistors? It doesn't say mills on the one I'm looking at for .25 cents. Wirewound resistor right?
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    Never mind I found them, they're in audio grade resistors thanks
  • ben62670
    edited April 2008
    You are doing an excellent job of answering your questions:p:)
    Ben
  • domesda2b
    domesda2b Posts: 89
    edited April 2008
    ben62670 wrote: »
    You're a fantastic human being my friend and I couldn't of done it without some good directions. Hey just point me in the right direction. I'm almost ready to check out! I even remembered the musical solder WHOO-HO! Nothing to it. I'm excited.
