One last amp/watt question
2
    edited April 2008
    Hawkeye wrote: »
    I've been following this "be" guys threads and have come to a couple conclusions.
    1. The guy is one of those brand lovers to the death. Chevy, Ford, Dodge, Sony or Onkyo........put in any brand and there will be a die hard. Can't change or reason with people like that. When the AVR smoke checks, he'll buy another of the same brand and chalk it up to just a bad piece that got through QC.
    2. He's not here for advice, perhaps trying to salve his buyers remorse by saying his stuff is .........?
    3. Some of the car analogies don't make sense to me but I overlook those. He does not know cars either.
    You folks have given him some pretty good, sound (no pun intended) advice which he chooses to ignore.
    Gordo
    I am not ready for amplifiers. :p
    Then what do you people think about B&K AVR 507 S2 ($3,300) or Arcam AVR300 ($2,000)? They are receivers too, and no one has said anything bad about them for using with the LSi's. Can anyone tell me why it has been the case?
    But if anyone of you guys pisses me off, then I might just go ahead and spend another $2,000 for the amplifiers! :rolleyes:
    edited April 2008
    Jeez we even have newbies giving another newbie advice & it's not getting through!
    As I stated before, just put him on ignore. Saves everyone time, typing, & aggravation!
    Welcome Hawkeye & DJ.
    edited April 2008
    be83663 wrote: »
    Wow you found the solution. Run out and spend $2000-3000on an AVR. Brilliant. What an F-tard. Thanks for wasting our time. I hear Bose calling your name. Bub By.
    Ben
    edited April 2008
    cfrizz wrote: »
    Hey...
    I'm a noob I know :o
    But I'm trying damn it.
    I should've listened way back in 2008, they told me I'd go broke... they were right
    edited April 2008
    ben62670 wrote: »
    What did you get in any sort of your reading comprehension exams? You would know that what you think I am saying is not what I meant if you read what I had written carefully; don't let people readily discover that your I.Q. actually is a two digit! :D
    Who says I am spending $2,000 for a receiver? I know at least dkg999 and jayman 1975 are, but it is not me. And how did you know that all the cables I use for my set-up are Monster series cables; is it because you use something fancier? I am not living in your level, and I don't plan to! :cool:
    edited April 2008
    be83663 wrote: »
    What did you get in any sort of your reading comprehension exams? You would know that's not what I meant if you read what I wrote carefully; it's because your I.Q. is a two digit. :D
    Thanks BP it is actually 135. How have you done on listening exams?
    If you had half a brain you would realize that people are trying to help you. Why in the world would you spend $2000 on an AVR? You can get a nice Pre, and an amp under that. I guess you are just a little to stuck in your ways to listen when people give you good advice.
    Forget it dude you are just way to thick to even bother with. Go get your Onkyo, and be marry. You will be bliss, and never know what you are missing out on.
    Ben
    edited April 2008
    Hey Ben,Ya think now is a good time to sell this dude some cables??:p:D
    Just f#%kin' with ya....:D
    edited April 2008
    tonyb wrote: »
    Wouldn't even bother:D I would send him off to circuit city to get some nice Monsters;)
    Ben
    edited April 2008
    I know you are trying & you are doing a great job. It's just a shame you are talking to someone who is thick as a brick and twice as dense!:D
    Keep up the good work!
    djlogix wrote: »
    Hey...
    edited April 2008
    I think we are being too hard on BE, he saved up his allowance for years to buy the LSi's. It would take him another 5 years if he needs an amp also...
    edited April 2008
    Yeah I was kinda thinking he may have a paper route or something. I remember when I was running 110wpc receiver, and thought it was the bomb:cool:
    Ben
    edited April 2008
    What was the question again??
    2 Channel rig:
    LSi9"s (modified xover's) & HSU Sub
    Harman Kardon HK 990 Amp
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
    HK AVR-745 & Polk Monitor Series
    edited April 2008
    Hi, guys. I just wanted to let you know that I changed my mind again and decided to get $500 7-channel Emotiva LPA-1 amp that produces 225wpc @4-ohms for 5 channels at THD of 0.04%, 1 kHz, all channels driven. Its 6th and 7th channel only produce 95wpc; so I will just use my Onkyo 805 for those two for my back surround speakers, and not use the Emotiva's. Like I said, my receiver has certified 4-ohms performance; so I am sure it will produce enough currents for at least two LSi9 speakers simultaneously around 150wpc, THD of <0.05%, 1 kHz, before clipping; and it is only for surround back speakers that you can live without or that produce sound which is the same as surround side speakers in most 5.1 movies. I don't want to waste my receiver's amp section as well as in this way, LPA-1 will have to supply currents only to 5-channels as supposed to all 7-channels, thus do a better job for those five channels, namely two fronts, center, and two surround sides.
    So I decided to spend $800 on LPA-1, amp stand, and RCA cables instead of spending that same $800 on upgrading my receiver to Onkyo TX-NR805 with a toroidal transfomer and separate transformers for audio and video processors. LPA-1 has a toroidal transformer too; so my current receiver Onkyo TX-NR805 would have to use its regular transformer to supply currents to both audio and video processors, and two channels loaded with 4-ohms surround back speakers, which I believe it would be able to handle. Hopefully, I will get better sound quality in return this way!
    edited April 2008
    Wait... did you get the LPA or the XPA-5 ?
    And how the hell did you get it for $500 ?
    edited April 2008
    Buy a Parasound Amp ,You won't be sorry. They power LSi's GREAT.
    TV- 52 inch LCD SONY BRAVIA XBR6
    TV- 42 inch PLASMA HITACHI ULTRA VISION
    AMP- PARASOUND HALO A-51
    CONTROLLER- PARASOUND HALO C-2
    FRONT SPEAKERS- LSi15's and LSiC
    REAR SPEAKERS- LSi7's
    SUBWOOFER- VELODYNE DD15
    BLU RAY- LG SUPER BLU BH200
    BLU RAY- SONY BDPS350
    GAME SYSTEM- NINTENDO Wii
    MONSTER POWER CONDITIONER
    WIRES- AUDIO QUEST and MONSTER
    edited April 2008
    The LPA 1 is the 125wpc @ 8ohm amp.
    djlogix wrote: »
    edited April 2008
    LPA-1 for $500 of course.
    Thank you everyone for your advice, even cfrizz who likes to ignore me, because I wouldn't have learned about Emotiva product without him mentioning it to demaples for the first time! It only took you guys 10 days to convince me to go for an amp instead of a receiver! ;)
    edited April 2008
    I hope it breaks.
    J/K:p
    Try it both ways so you can assist with stubborn noobies down the road:)
    Ben
    edited April 2008
    From "Water Boy" "Will you be my friend"
    I am sorry. That just makes me laugh.
    engtaz
    engtaz
    edited April 2008
    ben62670 wrote: »
    I hope it breaks.
    J/K:p
    I know. :cool:
    edited April 2008
    ben62670 wrote: »
    I did...I didn't have enough space at the time in my rack to add the amp. Only thing is the Arcam was $2000 worth of "music first" design and build quality. No auto-setup, no HDMI switching, no IPOD ready, no XM satelite compatible. I'm sure the $2000 ONK has all of those frills and piles more.
    If I was going to do it all over....if i had the room for seperates to begin with...i would not have bought the expensive reciever. But for the limited height allowance in my rack and no room for an external amp....the Arcam was exactly what i needed.
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
    edited April 2008
    I am still trying to get my head around the idea of pushing speakers with an amplifier. Some speakers are kind of top heavy; if you push them, they might fall over...
    If y'all would like to get some additional insight as to the paramaters that matter when it comes to amplification, you might want to peruse some of the "amplification" articles at: http://sound.westhost.com/articles.htm
    Not a bad primer on the topic.
    edited April 2008
    Just put my name on the order list for the Emotiva MPS-2, 300 wpc at 4ohms, $1699 free shipping, 5 year warranty, but on back order till June. Input?
    Hitachi 50" Plasma full HD 1080--Onkyo 805 AVR
    Rotel RMB-1077 amp--Polk LSic center
    Polk LSi25 fronts--Polk LSi 15 rears
    Genesis G-2800 sides--Polk PSW 650 sub
    APC H15 power conditioner--Netgear digital media player
    Napster external hardrive--Linksys Wireless G router
    Samsung DVD--Blue Jeans wires
    edited April 2008
    Congrats be, should be a great amp, I have heard very good things about the emotiva gear, they seem to be great bang for your buck.
    de, seems a little pricey, once you get over $1k alot of options open up. Should be a very nice amp but I would never buy it as it doesn't double down into a 4ohm load, has fans, and I am not a big fan of class H.
    edited April 2008
    Which one is class H? Emotiva?
    Is doubling down into a 4 ohm load a good thing? What kind of amps do that?
    edited April 2008
    There are a pile of amps recomended on here that don't double down. I wouldn't get to hung up on that issue.
    Arcam CD37
    Vandersteen V2W
    edited April 2008
    Agreed. Most amps that are affordable don't. The ones that do cost BIG bucks!
    edited April 2008
    Read the specs of the amps that claim they double the power into 4ohms. The distortion specs are often much higher than the ones that are willing to compare apples to apples.
    Ben
    edited April 2008
    Looking at the specs on my Cinenova and it has lower distortion at a 4ohm load then a 8ohm load, and it doubles down just fine. All Icepower amps I have tried keep the same distortion rating while doubling down. Sunfire is another that comes to mind. I guess these seem to be the exceptions to the rule though, as many brands don't.
    Mighty, a amp doubling down is a show of its ability to produce current. The closer it can get to doubling power into a 4ohm load the better. It also shows that the amp will be more stable with not only lower impedance speakers like the LSi series but also ones with large impedance swings.
    edited April 2008
    Currently have LSI 15's front, LSIC and LSI FX surrounds. I purchased a 3808 back in November and didn't take the 4 ohm impedance into account.
    I currently have a 6.1 set up and will eventually go with 7.1 once I get an okay from my better half to give up the garage and build a dedicated HT.
    I need a suggestion on an amp that I can team up with my 3808 and not break the bank. I've read in some forums that AVR's don't make good pre's so suggestions are welcome.
    Thanks in advance.
Welcome!
Welcome!
