Blu-ray video adjustment disc
dholmes
dholmes Posts: 1,136
edited April 2008 in DIY, Mods & Tweaks
Would there be any benefits in getting the blu-ray video adjustment disc? Does anyone have one?
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2008
    If your television is calibrated properly in the first place, what's the advantage of using a BR disc to do it? It sounds like marketing to me but I haven't seen one yet.
    Link?
  • dholmes
    edited March 2008
    I thought it was bs,just wanted another opinion.thanks
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2008
    It's just another calibration disc, no different from DVE or Avia.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • dholmes
    edited March 2008
    I thought that since it is blu-ray that it would calibrate clearer pq.
  • dorokusai
    edited March 2008
    The only way to get a better picture than the disc is by having an ISF technician stop by. Otherwise, use the DVE or Avia.
  • dholmes
    edited March 2008
    Thanks,techs are toooo much $$
  • cnjvh
    cnjvh Posts: 253
    edited April 2008
    Both DVE and Avia use rec. 601 color/tint patterns, not rec. 709 (which is standard for HD resolutions).
    DVE and Avia will work fine for brightness/contrast/grayscale adjustments and color/tint adjustments if you set your player for a SD resolution output.
    They will not work for color/tint adjustments using an HD resolution output (unless you can verify your player converts rec. 601 to rec. 709 when upconverting).
    No earth robot is going to tell ME which button to press!!
    --Stuff--
    Front: Polk Audio RTi12
    Center: Polk Audio CSi5
    Surrounds: Polk Audio RTi8 (x4)
    Sub: SVS PB10-ISD (Dual)
    AVR: Denon AVR-3805
    Blu-Ray: Panasonic BD30
    Display: Sony KDL-55NX720B
    STB: Xfinity X1DVR
  • steveinaz
    steveinaz Posts: 19,546
    edited April 2008
    DVE gets you 98% there. Any better would require an ISF calibrator anyway. I did my 50" DLP this way, it looks great.
  • Serendipity
    edited April 2008
    steveinaz wrote: »
    Depends on the display. With a DLP, you can get pretty good results with a calibration disc. But with other displays that have mechanical adjustments (sometimes you need more than just a screwdriver), like CRT projectors, a calibration is really necessary :)
