Blu-ray video adjustment disc
dholmes
Would there be any benefits in getting the blu-ray video adjustment disc? Does anyone have one?
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
If your television is calibrated properly in the first place, what's the advantage of using a BR disc to do it? It sounds like marketing to me but I haven't seen one yet.
Link?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I thought it was bs,just wanted another opinion.thanksMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
It's just another calibration disc, no different from DVE or Avia.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
I thought that since it is blu-ray that it would calibrate clearer pq.My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
The only way to get a better picture than the disc is by having an ISF technician stop by. Otherwise, use the DVE or Avia.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Thanks,techs are toooo much $$My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Both DVE and Avia use rec. 601 color/tint patterns, not rec. 709 (which is standard for HD resolutions).
DVE and Avia will work fine for brightness/contrast/grayscale adjustments and color/tint adjustments if you set your player for a SD resolution output.
They will not work for color/tint adjustments using an HD resolution output (unless you can verify your player converts rec. 601 to rec. 709 when upconverting).No earth robot is going to tell ME which button to press!!
--Stuff--
Front: Polk Audio RTi12
Center: Polk Audio CSi5
Surrounds: Polk Audio RTi8 (x4)
Sub: SVS PB10-ISD (Dual)
AVR: Denon AVR-3805
Blu-Ray: Panasonic BD30
Display: Sony KDL-55NX720B
STB: Xfinity X1DVR -
DVE gets you 98% there. Any better would require an ISF calibrator anyway. I did my 50" DLP this way, it looks great.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Depends on the display. With a DLP, you can get pretty good results with a calibration disc. But with other displays that have mechanical adjustments (sometimes you need more than just a screwdriver), like CRT projectors, a calibration is really necessary
