Converting LSi15 to LSi9
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2008
    Shoot the cat, and deep 6 the Lsi15 mod idea. :D
    VR3 Posts: 29,399
    edited March 2008
    The LSi15 and the LSi9 both feature power port and ARC port technology.
    The LSi9's power port is on the back.
    The LSi15 is on the bottom - doubling as a base.
    Just wanted to correct the previous statement...
  • SlowcarIX
    SlowcarIX Posts: 887
    edited March 2008
    the LSi15 MTM section is not connected to the lower section (side firing woofer) and sharing the ARC port is it?
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • SlowcarIX
    edited March 2008
    what a difference between the 9 and 15, andrea bocelli sounds so throaty - i like it!
    my 7.(1x4) HT setup
    Buttkicker
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    SlowcarIX wrote: »
    No..
    Ben
  • Face
    Face Posts: 14,340
    edited March 2008
    You are insane. :D
  • Gaara
    Gaara Posts: 2,415
    edited March 2008
    Please tell me you didn't compare 9s with 15s with totally different positions? You could compare two sets of 9s and they will sound vastly different when one set is a foot higher then the other and against the side walls. Location location location.
  • SlowcarIX
    edited March 2008
    that was 1st impressions after 2 mins of listening, of the differences in sound output from the 2
    my 7.(1x4) HT setup
    Buttkicker
    tonyb Posts: 33,068
    edited March 2008
    Gaara wrote: »
    My thoughts too,plus,try and move that gear off the carpet,static ya know.Go to any home depot and get some patio blocks to put underneath.Granite would look better but for the 5 bucks a patio block would cost,you can't go wrong.Toe in those 15's too and move forward about a foot.
  • mightymouse
    mightymouse Posts: 254
    edited March 2008
    So which one sounds better?
    And BTW, I like where your 9's are sitting. I have mine sitting on two fold up chairs as well (just a temporary solution until I get around to assemble my speaker stands). Great minds think alike.:D
    SlowcarIX wrote: »
  • SlowcarIX
    edited March 2008
    i like the LSi9 better - they got a "fuller" sound to them
    they play 80Hz and up when i compared the 9 and the 15. when the conquest sub comes next week, the sub will play 60Hz and below and LSi9 will handle the 60Hz upwards
    my 7.(1x4) HT setup
    Buttkicker
  • mightymouse
    edited March 2008
    That "fuller" sound must be that midbass hump everyone has been talking about.
    If I remember correctly, people have been saying that in order to boost the perception of more bass from bookshelf speakers, Polk added a midbass hump to the 9's, to make them sound like they are giving out a ton of bass.
    The 15's don't have this hump, because the 15's have that dedicated 8" woofer to deal with the midbass and bass.
  • SlowcarIX
    edited March 2008
    that must be it then
    when i do room calibration with the sms-1 next week, i'll remember to take a on-screen shot of whats going on in the mid-bass region
    my 7.(1x4) HT setup
    Buttkicker
  • SKsolutions
    SKsolutions Posts: 1,820
    edited March 2008
    Get taller chair-stands (barstools), and pull them out 4 feet from the rear, and 5 feet from either wall. Sit back and enjoy. Keep the 15's for HT.
    -Ignorance is strength -
  • SlowcarIX
    edited March 2008
    speaker stands are somewhere in transit now, the foldup chair is temp setup because i want to blast them and break them in this few days
    i got a square 20x20 which limits what i can do and still following this arrangement
    1 multi-purpose system is enough for me - i like movie/sound enough but not to the extend of seperate systems
    my 7.(1x4) HT setup
    Buttkicker
  • mightymouse
    edited March 2008
    What kind of speaker stands did you get?
    You need something that is around 30" for those 9's.
    I ended up getting the Target MR28 stands from audioadvisor (which I still haven't assembled yet, too lazy...).
  • SlowcarIX
    edited March 2008
    my 7.(1x4) HT setup
    Buttkicker
  • mightymouse
    edited March 2008
    Looks nice. Make sure you fill up the stands with sand. The sand has to be dry, otherwise it will cause rust.
  • SlowcarIX
    edited March 2008
    i really want to fill the stand with lead shots...but i'm having difficulty finding it in Austin
    my 7.(1x4) HT setup
    Buttkicker
  • ben62670
    edited March 2008
    SlowcarIX wrote: »
    Check with the local gun stores. Lead shot is used for reloading shotgun shells.
    Ben
  • SlowcarIX
    edited March 2008
    i called several gun shops here and they do not have shots...i guess reloading is not popular here....:confused:
    my 7.(1x4) HT setup
    Buttkicker
  • ben62670
    edited March 2008
    Shoot dude(:D) I would have thought shooting would be a favorite Texas pastime.
    Ben
    tonyb Posts: 33,068
    edited March 2008
    Re-loading is what they don't do well.
    They hit what they aim at the first time.
  • SlowcarIX
    edited March 2008
    ben62670 wrote: »
    lol...seems that ppl here just buy shot shells in boxes
    my 7.(1x4) HT setup
    Buttkicker
  • bbeacham
    bbeacham Posts: 141
    edited March 2008
    tonyb wrote: »
    Can you expand on this statement about carpet? This is the first I have heard that sitting on carpet can degrade the sound quality. Thanks.
    tonyb Posts: 33,068
    edited March 2008
    bbeacham wrote: »
    Static can build up even if your gear isn't directly on the carpet.Being on it though won't help.You may start hearing a fuzzy sound.Some have even toasted some gear from static shock.Lots of anti-static stuff out there.If you are the type to shuffle your feet walking over to the gear,ground yourself on something else first.High humidity plays a role in it also.Wool carpets being the worst for static.
  • SKsolutions
    edited April 2008
    You won't need a ton of bass in that room, if it's well placed.
    With a square room, try some odd placements, at odd intervals or you will get uneven in-room response -nulls, modes.
  • Face
    Face Posts: 14,340
    edited July 2008
    How about this...take a LSi9, use a LSi15 crossover, and build a cabinet made to house a LSi15 woofer front firing. The cabinet could also be used as a stand. Or, use two 8" dvc DB series woofers configured to 4 ohms and place them in a cabinet under the LSi9 for more surface area and less distortion.
  • iskandam
    iskandam Posts: 704
    edited July 2008
    SlowcarIX wrote: »
    i got more low end out of them by facing the woofer inwards
    I was thinking about doing this too. Did this placement affect imaging in any way?
    I also tried plugging the power port at the base but it ended up making the bass way too boomy
  • phxrider
    phxrider Posts: 58
    edited August 2008
    SlowcarIX wrote: »
    Do they have shooting ranges near you? Go to one and ask around if anyone reloads, then find out where they get their stuff. You might have to order it.
