i need HELP!
bv122046
bv122046 Posts: 4
edited March 2008 in Car Subwoofer Talk
ok i am 15 years old and i have no clue on what to do for subs. So i am willing to pay from $1000 to $2000 for my subs. I have a ford explorer so i have plenty of room in the back. I just need advice on what is best thing i get with that money and i'm talking about for subwoofers, amps, and box. all i want is to have a nice set and i want to atleast want to have a good loud bass. and lastly i want everyone at my high school can hear my bass in the parking lot. thank you for help
Post edited by bv122046 on
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2008
    bv122046 wrote: »
    Oh well, I mustnt judge. At least youre willing to spend some money on some quality gear.
    Well there are a couple ways to go. If youre wanting to simply drop in a box and an amp then, no question, the DB212-2 is the best one on the market. Lots of output and sounds awesome!! Get it and power it with a good amp thatll make 750-800 watts RMS at 2 ohms mono and go get em.
    If youre up to building the box yourself, then Id suggest going and getting a couple Kicker L7 12's and power them accordingly.
  • mirra540ryder
    mirra540ryder Posts: 136
    edited March 2008
    for 2000 id go with 4 momo 15''s and a rockford p1000 amp in a nice vented box and they will hear you for about 2 mins before u get there. i got three and i got the loudest system in town with that amp
  • mirra540ryder
    edited March 2008
    that will run you about 1500
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    I hate L7's. My buddy had them in 15", and they are such ghetto blasters. You can deffinetely get points for loud, but SQ just sucks. Slow rubbery rap bass.
    Ben
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited March 2008
    Type Rs.... or get a sledghammer... lawl
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • Kinetic
    Kinetic Posts: 437
    edited March 2008
    as Mcleod said, for a nice SQ and loud bass the DB212-2 and also should be easy to install
    for something louder, use the cerwin vega stroker, (2,000 RMS)
    http://www.cerwinvegamobile.com/stroker15.php
    Z
    /////Alpine CDA-9887 HU
    /////Alpine KTX-1000EQ
    /////Alpine PDX-4.150
    /////Alpine PDX-1.1000
    Polk Audio SR 6500
    Polk Audio SR 124 DVC
    KnuKonceptz MKS Kable
    G35
    /////Alpine SPX 17PRO
    /////Alpine SWX 1243D
  • MacLeod
    edited March 2008
    ben62670 wrote: »
    I think they sound pretty good. They are insanely popular in SPL circles but all the ones Ive heard generally sound pretty good.
    They do make some major noise tho. Ive seen a **** ton of these things in winners circles with some very high SPL levels.
  • eloplayspolo
    edited March 2008
    i think if u got 2 or 3 of these and put them in a BIG ported box... u would get exactly what ur looking for.... read the reviews (they usualy dont mean ****... but in ur case... i think its what u want)
    http://www.crutchfield.com/App/Product/Item/Main.aspx?g=520&i=500SWR1542&tp=111&tab=review
    then power them with http://www.crutchfield.com/App/Product/Item/Main.aspx?g=120&i=500PDX1100&tp=115
    2013 Toyota Prius
    Mosconi 6to8 v8
  • bv122046
    bv122046 Posts: 4
    edited March 2008
    so should i get 2 of the alpine PDx. or just one
  • bv122046
    bv122046 Posts: 4
    edited March 2008
    And also what would be a good ported box for the alpine subs if i was gonna go with 2 subs
  • eloplayspolo
    edited March 2008
    yeah get 2 of them. go to a car audio shop near u and have them make a big ported box
    2013 Toyota Prius
    Mosconi 6to8 v8
  • tinman67gz
    tinman67gz Posts: 15
    edited March 2008
    Polk momo subs are the real deal. I don't have much room as I have an F-150 extendend cab and wanted the speakers under the back seat. I got 2 momo 8" and built sealed boxes for them (sealed boxes don't give you the boom you will want they give a tighter bass but you can make the box smaller). Those 2 momo 8" subs ROCK!!
    You will want 12 or 15's and a large ported box. Check crutchfield.com for the speakers and prefab boxes or sugesstions on building your own box. The key is in sizing and sealing the box and sizing the port correctly. Also matching you sub to your amp.
  • mirra540ryder
    edited March 2008
    why go with 2 alpine 15's while for about 100 dollars more go with 4 momo 15s momo momo MOMO!
