7 Channel amp Vs. 7 monoblocks
Yes, it was my first real serious system & that was what was recommended to me at Spirit Sound 18yrs ago, back when they sold Polk speakers. I only wanted to spend around 2000.00 total on my new system.
So I got my RTA 8T's the Rotel RB850 50wpc amp, the matching 850 preamp/tuner, the Rotel RCD855 cd player, & the Onkyo tape deck that is in my signature. All I kept from my older system is my now 27yr old Sony Turntable also, in my signature.
I thought it sounded great, even better than my older system. I had no clue that amps came in higher wattage or that it could make an even bigger difference to my speakers until I joined this crazy joint in 2004!You owned an amp of only 50 watts?VenomMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
In my opnion mono blocks are for audiophiles. Having everything seperate is nice. If you where going to put each amp close to the speaker , that would be cool but not practical.
5 or 7 channel amps are the way to go always. I also feel 2 channel amps are fine even for audiophiles. Mono blocks are just like having a 454 big block in your muscle car.Dan
LOL, so which amps do you think are not for audiophiles? You did leave out 3 and 6 channel amps, why no love for them?
FWIW, I have 3 monos and I am looking at ditching them for a single 5-7ch amp.
If you blow a channel on the Earthquake you can just remove the one channel and send it in.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
How about seven wall plugs and one amp?B&W 804s mains
B&W HTM4 center
Polk PSW 1000 sub
Outlaw 990 Pre Amp
Anthem MCA 30 Amp
Monitor Radius 180 surrounds
Audiosource Stereo Amp for surrounds
Denon 2910 Universal DVD/SACD Player
Comcast DVR
Pioneer Elite 42" Plasma 940 HD
Harmony Universal Remote
Blue Jeans interconnects and biwires
Itunes Air Express -
I have never heard them but what about the fact Outlaw monoblocks operate in G/AB modes? That would steer me towards the multi-channel amp.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
I used them once for two channel and they sounded grainy and harsh IMO. For HT surround channels they are great though and I would use them again in that capacity. Not the front stage though.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Be different, go for the 7 mono blocks, gear is cool and there's lots of "wow" factor when you have guests over.
Wiring....no big deal....a few strategically placed tie wraps and careful placement of the wires and you're done. It's not that you have to fiddle with the wiring everyday, once it's done, it's done.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
I'm sorry but buying gear just so you can have a WOW factor when guests come is just....lame.
It should be about getting the best out of your equipment & making the wisest decisions for what you want to accomplish. That does NOT include a WOW factor.
A seven channel amp will get the job done very nicely & only take up one outlet. Leaving you with another/others that can be put to better use.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
how about an icepower 7 channel amp? they are efficient and robust (i shorted the speaker banana jacks a few times as i forget they are on - makes a big spark and still alive and well)
for ~2600, you get 3 X 500W and 4 X 250W
http://www.d-sonic.net/my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
D-Sonic is good stuff, I back up Slow's suggestion. On another note, Shannon W. runs 7 monos, you might find them displayed in his showcase, and they look good in his rack. Do a search and Im sure it will come up. I love the mono amps Outlaw offer. They are capable of big things.
for the price this adcom may serve you right
http://www.onecall.com/ProductDetails.aspx?id=30357Shoot the jumper.....................BALLIN.............!!!!!
I've had a good number of responses. Thanks folks.
What is the difference in current draw between the 7 channel amp and 7 monoblocks. Will you need additional dedicated circuits? Just a thought.[
Not to mention the expense of the 7 sets of interconnects you'd have to buy because ofthe7 monoblocks........factor that into the overall cost of mono vs. 7ch.........comment comment comment comment. bitchy.
He will need 7 single interconnects. Makes no difference if they are mono or in a single chassis. -
LOL! Have another cup of coffee Brett!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I was thinking that having seven special aftermarket powercords, would make it sound better than one alone.
You can still get the 7500 from Outlaw...
Your price or your spec is off, the 3x500 + 4x250 is $3k, the 3x500 + 2x250 is $2590. When you can get a 5x100 for <$1k these will really catch on, Rotel is almost there with their $1199 RMB-1085. -
i was refering to the d-sonic m1250-7 for $2575:
8 ohms - 3x250w + 4x125W
and since hiccups is driving 4 ohm LSi
the power doubles - 3x500W + 4x250Wmy 7.(1x4) HT setup
Buttkicker
My b. Usually the 8ohm spec is quoted but we are talking about LSi so your right.
Nuforce is coming out with a 7 channel amp...should be cool.
There was a salesmen @ Magnolia (although informative and a cool guy) trying to make a selling point for McIntosh versus my interest in the Emotiva XPA-5 with the whole balanced versus unbalanced thing. I guess he's using a Yammy AVR as well, but confessed he's not familar with the Emotiva.
Damn I need a drink.I should've listened way back in 2008, they told me I'd go broke... they were right -
If I recall correctly it was 4k for that 7ch, a little pricey imo. I can't wait for the >$1k 5ch icepower amps, shouldn't be to far away. -
LOL! Salesmen! Stick with the more reasonble Emotiva. Mostly what you would be paying for is the Mac name!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Outlaw makes some nice ampsB&W 804s mains
B&W HTM4 center
Polk PSW 1000 sub
Outlaw 990 Pre Amp
Anthem MCA 30 Amp
Comcast DVR
www.gemstoneaudio.com
400w/ch x 7
call Jerry for a 15 days in-home money back trial and check it out yourself.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
If the only thing a salesman can come up with to make you decide between Mcintosh and Emotiva is balanced and unbalanced, he's a moron.
Mcintosh is your last piece of gear. Its something you can pass down to your kids and they can pass to their kids. They hand make everything in their amps, from the circuit board to the transformers. Hand pick the capacitors and everything. And they will still service it twenty years from now.
Mcintosh is a REAL amp.
Period.
To compare it to Emotiva on any other level other than amplifying a signal is crazy.
Also, I'd take 7 Mono Blocks over a 7 channel amp anyday of the week. If a channel breaks, Im out an amp, not all of my channels. And 7 power supplies has gotta be better than two big ones!
