Converting LSi15 to LSi9
SlowcarIX
SlowcarIX Posts: 887
edited August 2008 in Speakers
I am thinking about it because the M/T/M array on the
LSi15 goes from 150Hz to 27KHz (leaving the side firing woofer out) and the
LSi9 from 38Hz to 27KHz...i want a wider range from the LSi15 mtm array
there is quite a bit of info below 150Hz thats too far from the ears
http://en.wikipedia.org/wiki/Vocal_range
any down side to this conversion?
has anyone done this mod b4 and can i buy the LSi9 xover from polk?
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Post edited by SlowcarIX on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    While not an exact to spec mod you could take a double pole double throw switch, and have it both ways. There is a 130uf cap that blocks the bass from reaching the upper drivers, and the sub could be disconected. I don't know how handy you are DIY, but a switch wouldn't be to hard to do, and you would not detract from the performance in "LSI15 mode".
    Ben
  • ohskigod
    ohskigod Posts: 6,505
    edited March 2008
    i"m spitballing here, but are you actually hearing an issue with the response below 150, or just uncomfortable with the fact that 150 and below comes out the side woofer?
    if your hearing something off on your bottom end, make sure your giving the 15's room to breath out the side and play with placement. effing with the crossover is just not worth it in my eyes.
    even if you make the top part into an LSi9, its a different internal volume, which is gonna throw **** off anyway.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2008
    There is far more unheard information in the upper register, for most people, than the lower.
    Yes, you may purchase the xover from Polk, but why? Have you found a new way to design a loudspeaker, based on a single event?
  • SlowcarIX
    edited March 2008
    perfect
    will call polk in the morning and get a pair of LSi9 xover and make myself a pair of LSi12
    my 7.(1x4) HT setup
    Buttkicker
  • ben62670
    edited March 2008
    Have you looked at the cutaway of the 9's. I don't think the 15's, and the 9's would share the same XO cutout. Have you looked at the schematics yet. I wouldn't be too quick to tear them apart without a little more thought.
    Ben
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2008
    :eek::eek::eek::eek: FrankenPolk LSI's????? Oh the horror:eek::eek::eek::eek:
    edited March 2008
    Why not just sell the 15's and get the 9's with a good sub?
  • SlowcarIX
    edited March 2008
    cfrizz wrote: »
    ;):):p:D
    my 7.(1x4) HT setup
    Buttkicker
  • Face
    Face Posts: 14,340
    edited March 2008
    tonyb wrote: »
    I agree, just sell them and buy the correct items for your needs.
  • engtaz
    engtaz Posts: 7,669
    edited March 2008
    I heard that Bose work good in the sound spectrum.:eek:
    engtaz
    engtaz
  • SlowcarIX
    edited March 2008
    tonyb wrote: »
    LSi9 + 28" speaker stand + 1 bengal cat = broken LSi9
    so besides wanting to extend the lower range of the MTM array, i want those speakers to last more than a day :)
    ~30lbs speaker falling over 2ft...it will be messy :eek:
    my 7.(1x4) HT setup
    Buttkicker
  • venomclan
    venomclan Posts: 2,467
    edited March 2008
    ohskigod wrote: »
    I agree, I would make changes elsewhere before tearing open and possibly messing up the Lsi15's. I presume you are talking about mainly 2 channel performance, try moving the speaker closer to you and toeing them in a little. It looks like you are sitting back a bit and the first reflection points of your right speaker can be hitting your front door alcove without toe in. The stacked subs are also interfering with your soundstage. Also pull the 15's out from the back wall and into the room more, it will not look as nice but should improve the sound substantially.
    It looks like you have a wide glass-topped coffee table in front of the couch, if you are that critical of the sound that you are going to change your crossovers, I would nix the table first.
    Through my research and speaking with industry pros here and there, it is of the opinion that Ice power amps do not perform as well with ohm dips. Being that the 15's are 4 ohm, this may be a challenge at the lower register.
    Every amp is different, some amps are "restricted" when plugged into a power conditiner. Try changing from the high voltage outlet to one of the digital banks on the PF60 and see if you hear a difference. Also try bypassing the PF60 altogether for the amps. I have the PF60 also and like it a lot, but at the end of the day, plugging a high end amp and AVR into a $200 conditioner may not have all its potential. Good luck.
    Venom
  • mightymouse
    mightymouse Posts: 254
    edited March 2008
    What kind of speaker stands were those?
    I just purchased a pair of Target MR28 speaker stands. I hope those wont be bumped over by a cat. :)
    SlowcarIX wrote: »
  • SlowcarIX
    edited March 2008
    Polk CS gets 10/10!
    the downside to this conversion = port noise
    the LSi15 does not have rear port like the LSi9 and all the breathing will be thru the 2 little front ports...low frequency = large cone movement = lot of air moved = annoying port noise. So thats that for this project :o
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited March 2008
    i got the 28" by measuring from the ground to the MTM section on the LSi15
    for my case, the cat jumping from the ground to the top of the LSi15 is not the problem...its the leaping from the LSi15 to the top of the tv shelf is what i'm worried about :(
    my 7.(1x4) HT setup
    Buttkicker
    edited March 2008
    SlowcarIX wrote: »
    One hell of a cat....get stands that can be filled with lead shot so they won't get knocked over....and a spray bottle filled with h20 for that cat when he goes near 'em.
  • SlowcarIX
    edited March 2008
    i put these carpet protector (vinyl sheet with spikes on one side) to help keep him off. You can get it from home depot...it works 80% of the time...when he goes nuts...it does not make a diff with them on :mad:
    my 7.(1x4) HT setup
    Buttkicker
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited March 2008
    One spray of cologne or perfume on the area helps too.
  • Face
    Face Posts: 14,340
    edited March 2008
    I would try pepper spray.
  • cfrizz
    edited March 2008
    LOL! That's the risk you take with cats. They love being on top of the world & will jump on anything that will get them there!
  • SlowcarIX
    edited March 2008
    this is turbo, the 15lb bengal
    my 7.(1x4) HT setup
    Buttkicker
  • candyliquor35m
    edited March 2008
    I've also found if you put a small vase or almost anything on top so it appears there's not enough room for them, they are usually smart enough not to try it.
  • Face
    Face Posts: 14,340
    edited March 2008
    One of these on top of each speaker would probably work too.
  • SlowcarIX
    edited March 2008
    these might work well too :eek:
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited March 2008
    venomclan wrote: »
    Venom
    the icepowered amps put out 500w@4ohms - is that an issue only when driven hard?
    the slab of glass will be moved
    my 7.(1x4) HT setup
    Buttkicker
  • michael_w
    michael_w Posts: 2,813
    edited March 2008
    As long as it doesn't touch the piano black finish ;)
    When I read the title of this thread I was picturing Las's thread about taking a chainsaw to a polk and cutting it in half...
  • SlowcarIX
    edited March 2008
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited March 2008
    michael_w wrote: »
    lol, chainsaw it into 1/2 and boring a hole at the back of the cabinet :D
    my 7.(1x4) HT setup
    Buttkicker
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited March 2008
    Why do you have the speakers reversed?
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • SlowcarIX
    edited March 2008
    i got more low end out of them by facing the woofer inwards
    my 7.(1x4) HT setup
    Buttkicker
