Converting LSi15 to LSi9
I am thinking about it because the M/T/M array on the
LSi15 goes from 150Hz to 27KHz (leaving the side firing woofer out) and the
LSi9 from 38Hz to 27KHz...i want a wider range from the LSi15 mtm array
there is quite a bit of info below 150Hz thats too far from the ears
http://en.wikipedia.org/wiki/Vocal_range
any down side to this conversion?
has anyone done this mod b4 and can i buy the LSi9 xover from polk?
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Buttkicker
Post edited by SlowcarIX on
While not an exact to spec mod you could take a double pole double throw switch, and have it both ways. There is a 130uf cap that blocks the bass from reaching the upper drivers, and the sub could be disconected. I don't know how handy you are DIY, but a switch wouldn't be to hard to do, and you would not detract from the performance in "LSI15 mode".Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
i"m spitballing here, but are you actually hearing an issue with the response below 150, or just uncomfortable with the fact that 150 and below comes out the side woofer?
if your hearing something off on your bottom end, make sure your giving the 15's room to breath out the side and play with placement. effing with the crossover is just not worth it in my eyes.
even if you make the top part into an LSi9, its a different internal volume, which is gonna throw **** off anyway.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
There is far more unheard information in the upper register, for most people, than the lower.
Yes, you may purchase the xover from Polk, but why? Have you found a new way to design a loudspeaker, based on a single event?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
perfect
will call polk in the morning and get a pair of LSi9 xover and make myself a pair of LSi12my 7.(1x4) HT setup
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
Have you looked at the cutaway of the 9's. I don't think the 15's, and the 9's would share the same XO cutout. Have you looked at the schematics yet. I wouldn't be too quick to tear them apart without a little more thought.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
:eek::eek::eek::eek: FrankenPolk LSI's????? Oh the horror:eek::eek::eek::eek:Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Why not just sell the 15's and get the 9's with a good sub?HT SYSTEM-
lsi 9's -
:):p:D my 7.(1x4) HT setup
Buttkicker
I agree, just sell them and buy the correct items for your needs.Why not just sell the 15's and get the 9's with a good sub?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I heard that Bose work good in the sound spectrum.:eek:
engtazengtaz
LSi9 + 28" speaker stand + 1 bengal cat = broken LSi9
so besides wanting to extend the lower range of the MTM array, i want those speakers to last more than a day
~30lbs speaker falling over 2ft...it will be messy :eek:my 7.(1x4) HT setup
Buttkicker
I agree, I would make changes elsewhere before tearing open and possibly messing up the Lsi15's. I presume you are talking about mainly 2 channel performance, try moving the speaker closer to you and toeing them in a little. It looks like you are sitting back a bit and the first reflection points of your right speaker can be hitting your front door alcove without toe in. The stacked subs are also interfering with your soundstage. Also pull the 15's out from the back wall and into the room more, it will not look as nice but should improve the sound substantially.
It looks like you have a wide glass-topped coffee table in front of the couch, if you are that critical of the sound that you are going to change your crossovers, I would nix the table first.
Through my research and speaking with industry pros here and there, it is of the opinion that Ice power amps do not perform as well with ohm dips. Being that the 15's are 4 ohm, this may be a challenge at the lower register.
Every amp is different, some amps are "restricted" when plugged into a power conditiner. Try changing from the high voltage outlet to one of the digital banks on the PF60 and see if you hear a difference. Also try bypassing the PF60 altogether for the amps. I have the PF60 also and like it a lot, but at the end of the day, plugging a high end amp and AVR into a $200 conditioner may not have all its potential. Good luck.
Venom -
What kind of speaker stands were those?
I just purchased a pair of Target MR28 speaker stands. I hope those wont be bumped over by a cat.
~30lbs speaker falling over 2ft...it will be messy :eek: -
Polk CS gets 10/10!
the downside to this conversion = port noise
the LSi15 does not have rear port like the LSi9 and all the breathing will be thru the 2 little front ports...low frequency = large cone movement = lot of air moved = annoying port noise. So thats that for this project
my 7.(1x4) HT setup
Buttkicker
mightymouse wrote: »What kind of speaker stands were those?
i got the 28" by measuring from the ground to the MTM section on the LSi15
for my case, the cat jumping from the ground to the top of the LSi15 is not the problem...its the leaping from the LSi15 to the top of the tv shelf is what i'm worried about
my 7.(1x4) HT setup
Buttkicker
One hell of a cat....get stands that can be filled with lead shot so they won't get knocked over....and a spray bottle filled with h20 for that cat when he goes near 'em.HT SYSTEM-
lsi 9's -
i put these carpet protector (vinyl sheet with spikes on one side) to help keep him off. You can get it from home depot...it works 80% of the time...when he goes nuts...it does not make a diff with them on :mad:
my 7.(1x4) HT setup
Buttkicker
One spray of cologne or perfume on the area helps too.
I would try pepper spray."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
LOL! That's the risk you take with cats. They love being on top of the world & will jump on anything that will get them there!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
this is turbo, the 15lb bengal
my 7.(1x4) HT setup
Buttkicker
I've also found if you put a small vase or almost anything on top so it appears there's not enough room for them, they are usually smart enough not to try it.
One of these on top of each speaker would probably work too."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
these might work well too :eek:
my 7.(1x4) HT setup
Buttkicker
Venom
the icepowered amps put out 500w@4ohms - is that an issue only when driven hard?
the slab of glass will be movedmy 7.(1x4) HT setup
Buttkicker
As long as it doesn't touch the piano black finishcandyliquor35m wrote: »One spray of cologne or perfume on the area helps too.
When I read the title of this thread I was picturing Las's thread about taking a chainsaw to a polk and cutting it in half... -
my 7.(1x4) HT setup
Buttkicker
lol, chainsaw it into 1/2 and boring a hole at the back of the cabinet
my 7.(1x4) HT setup
Buttkicker
Why do you have the speakers reversed?Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
i got more low end out of them by facing the woofer inwardsmy 7.(1x4) HT setup
Buttkicker
